metalsmith
Post by metalsmith on Jan 5, 2017 17:52:19 GMT -5
I found this 500g piece of marble fly-tipped on the Canary Island of La Palma. There's no marble naturally occurring there so it must have been imported then, surplus to need, abandoned. I cut this obelisk today. The obelisk is the apparently featureless longer left edge of the slab. There's still two-thirds more material to work with. It is tapered from 23mm to 16mm with the opposing faces straight at 20mm; length 103.6mm and coincidentally weight: 103.6g. All the faces are hand cut, except the base. That was the most problematic, because, I think, the length of the 'needle' magnifies the error. Method as below. Polished up quite nicely but tbh, there are a couple of areas need a rework just to bring the finish up to standard. Measure and mark with a pen; cut with a diamond blade - mine was a 40mm diameter pendant from my small bench grinder, but a dremel tool would be quite adequate. On a flat lap, the angles were squared at the obelisk base and the faces slabbed allowing for the taper. The 'peak' was coarsely cut by eye, making sure that the angle across the face kept square. The edges were bevelled again, by eye, balancing the obelisk on its edge and holding the angles between the faces and the lap equal. All of the above was repeated at finer 220, 600, 1200 grades Pre-polishing at 3000 grade and reworking the peak faces until the meet-points were achieved, again double checking the face angle is still square and the rest falls into place. Polish, here, oil-based diamond #3000 using a felt mop on a dremel pendant
Post by quartz on Jan 5, 2017 23:53:29 GMT -5
Nice, very well done.
Post by Fossilman on Jan 6, 2017 11:16:38 GMT -5
Liking the work and material!!
NDK
Post by NDK on Jan 6, 2017 11:20:00 GMT -5
Me too. Always had this in the back of my mind to try. Lots of work, you did a nice job!
Post by Pat on Jan 6, 2017 11:37:09 GMT -5
Biiiiiiig faceting job! Looks like fun.
metalsmith
Post by metalsmith on Jan 6, 2017 14:13:22 GMT -5
Fossilman Good material and free too ... all the better! NDK Yeah, I think maybe I underestimated the work and ran out of beans towards the end. I'll go back and finish the polish later. Pat I did the base with the facetter. I just couldn't get that to square off. Any one side was fine; rotate and do another; repeat, repeat, repeat - still not level. I was tempted to facet the faces too but I don't think dop wax sticks to marble very well. At least not when the prep lacked effort and the dust weakens the bond! Thanks for all your kind comments
Post by pghram on Jan 7, 2017 10:58:50 GMT -5
Nicely done!
Peace,
Rich
