Post by HankRocks on Jan 29, 2017 17:24:23 GMT -5
Some Lunkhead left the raised cushion that was in my large saw to reduce the distance between the rock being cut and the landing platform after the last cleaning. The result was a broken slab that I was going to polish on the Vibrating Lap. Any suggestions for which Epoxy to use to repair it. Will leave the slab whole afterwards for the Vib Lap. I will bevel the edges of both pieces for the Lap before repairing, but not bevel the broken edges.
Thanks
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Jan 30, 2017 14:23:52 GMT -5
Do not use Fast Cure epoxy, it is not waterproof and never completely hardens. Use a the regular 24 Hour Cure stuff for strength and reliability. Almost any epoxy should work and the most consideration should be paid to the color of the glue, look for something clear or transparent.
