insearchofspace
Member since January 2017
Post by insearchofspace on Feb 7, 2017 11:22:53 GMT -5
My Harbor Freight double barrel self destructed overnight after valiantly serving for 43 days. The bearings went, causing the motor mounts to melt. With the mounts loose, it ran the pulleys together, overheating the motor, and finally causing the motor to seize. Surprisingly it never broke a belt. In order to continue on my tumbling journey I ordered a 33b from the Rock Shed. My question is are the Chicago Electric barrels compatible with the new Lortone machine?
Post by Drummond Island Rocks on Feb 7, 2017 11:30:34 GMT -5
My Harbor Freight double barrel self destructed overnight after valiantly serving for 43 days. The bearings went, causing the motor mounts to melt. With the mounts loose, it ran the pulleys together, overheating the motor, and finally causing the motor to seize. Surprisingly it never broke a belt. In order to continue on my tumbling journey I ordered a 33b from the Rock Shed. My question is are the Chicago Electric barrels compatible with the new Lortone machine? Pretty sure the size of the barrels will match but the knurled nut will need to be replaced with the lortone ones that have a groove in them. The groove holds the barrels in place when rolling. Chuck
insearchofspace
Post by insearchofspace on Feb 7, 2017 11:37:02 GMT -5
I can probably just switch them out depending on which barrels I am using then. Only need 2 nuts at a time!
Post by Jugglerguy on Feb 7, 2017 11:44:58 GMT -5
My Harbor Freight double barrel self destructed overnight after valiantly serving for 43 days. The bearings went, causing the motor mounts to melt. With the mounts loose, it ran the pulleys together, overheating the motor, and finally causing the motor to seize. Surprisingly it never broke a belt. In order to continue on my tumbling journey I ordered a 33b from the Rock Shed. My question is are the Chicago Electric barrels compatible with the new Lortone machine? Pretty sure the size of the barrels will match but the knurled nut will need to be replaced with the lortone ones that have a groove in them. The groove holds the barrels in place when rolling. Chuck Nope, that nut only keeps the barrel in place on a QT66 or QT12. On the 33B, there is just a little nylon washer that the barrel rides up against. The nut doesn't touch any part of the base of the machine.
Post by Drummond Island Rocks on Feb 7, 2017 11:48:55 GMT -5
Pretty sure the size of the barrels will match but the knurled nut will need to be replaced with the lortone ones that have a groove in them. The groove holds the barrels in place when rolling. Chuck Nope, that nut only keeps the barrel in place on a QT66 or QT12. On the 33B, there is just a little nylon washer that the barrel rides up against. The nut doesn't touch any part of the base of the machine. Oh yeah, I have a couple 33B's but I forgot about that washer. On my homemade one I use the guides from the QT series for my three pound barrels too. I like them better then the washer. Chuck
insearchofspace
Post by insearchofspace on Feb 7, 2017 11:49:33 GMT -5
I'm going nuts!
pistal44
Member since February 2017
Post by pistal44 on Feb 7, 2017 11:50:02 GMT -5
I have a HF barrel on a Lortone 33b right now. Size is the same, nut doesn't make any kind of difference.
Post by orrum on Feb 7, 2017 12:41:58 GMT -5
The threads r different on the HB versus Lortone. I just use the HB barrel and let the nut rub on the metal dtandadr, been working for years that wsy!
Post by Garage Rocker on Feb 7, 2017 13:17:05 GMT -5
let the nut rub on the metal dtandadr Oh, okay.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Feb 7, 2017 13:34:08 GMT -5
I think I lost the dtandadr on my machine ?
Post by orrum on Feb 7, 2017 13:41:01 GMT -5
Drill a hole and use a bolt with a washer that can turn and let it hit the nut.
