Post by Peruano on Feb 20, 2017 19:26:39 GMT -5
I collect from beaches and alluvial deposits; hence many of my rocks are 1. small; and 2. round making them difficult to hold in a vice. Hence I stub a lot of rocks that others might not cut or would cut by hand with more variable results. I use carpenters glue and primarily 2x2 stubs, but the size can vary with the size of the rock. After a 24 hr cure time, the stub is clamped in the vice and cut made. This often allows me to get a pretty decent preformed cab with a single slice. Here is a piece of rhyolite which produced two slabettes each with a convex face that will dome quickly. Some will wonder isn't it difficult to remove the end piece from the stub. It took 14 seconds to cut this 2x2 with a simple hack saw (18 tooth per inch blade) leaving a thin slice of wood what will soak off with water and soap in a matter of minutes (prying with a knife blade can accelerate but some soaking through that thin sliver of wood is the key. I'll add some more difficult stub projects once I get a few more photos taken.
Post by Fossilman on Feb 20, 2017 19:34:25 GMT -5
I do the same thing too,but just throw the ends and wood into a five gallon bucket of water,let it set all summer,filling it up with the same thing... It's like xmas again when I sort out the rocks and throw away the wasted wood... Nice rock you cut there...........
Post by wigglinrocks on Feb 20, 2017 20:00:38 GMT -5
That's gotta be better than my cutting by hand thick and thin method
Post by orrum on Feb 21, 2017 9:27:50 GMT -5
Hey my question is how round of a rock can you glue to a flat 2x2?
Post by HankRocks on Feb 21, 2017 10:03:06 GMT -5
I like that idea and it's on my list of things to do. I saved all of the scrap 2x4's and 2x6's from an addition project.
Can you give us the brand name of Carpenters Glue you use? I go on the theory that all Glues are not equal.
Thanks
H
Post by Peruano on Feb 21, 2017 11:46:45 GMT -5
I wanted to cut a slot in the top of this rock to make a recipe hold (business card holder for those who don't cook) and I need to be able to take the rock out of the vice and turn it over so that the cut would be equal depth on both sides of the cut (instead of reflecting the curvature of the blade). Hence I stubbed it on the face of a long stub and flipped the stone over after the first cut and clamped to the other end of the stub. Yes I I had precut a flat spot on the bottom of the stone for gluing. How round can the stone be? Well that depends on how round relative to how big the stone. Often if I have an irregular gluing surface (round or otherwise), I'll place the stone in the glue and then shim with wood splinters and wedges. The glue holds both the shim and the rock, and you can accommodate a multitude of surface irregularlities. Brand name. I've use various, but don't go for the super water resistant ones. Right now I'm using Gorilla Glue's wood.carpenter's glue (not the foaming stuff, although it works to, but is harder to get off of the stone). Elmer's wood glue works for me too, but I firmly believe in an overnight cure and in real cold weather letting the cure be inside the house rather than in my supercold shop. I think the cold makes the glue more brittle and thus more likely to release from the stone. I've said it before but forgive a repeat. I reuse my stubs, but only after cutting off a fresh end for gluing to avoid mineral oil interference with glue grip. When stubs get too short, they become firestarters for my wood stove.
