Post by melhill1659 on Feb 24, 2017 0:53:08 GMT -5
I can't remember to whom I should give thanks for letting us know about this up for auction on eBay but THANK YOU! I'm it's new owner! It's the older model and a little louder than the new one but I love it. Since it's been used is there anything I should look at or be aware of? Also got this in today Didn't realize it needed its own concrete shop to bolt onto. Anyone want to share any pics of your Lot-O mounts?
Post by jamesp on Feb 24, 2017 6:08:00 GMT -5
Order one of these for Lot-O base. Check shipping costs first. Gotta read the fine print Mel.
Post by Drummond Island Rocks on Feb 24, 2017 7:02:28 GMT -5
Post by melhill1659 on Feb 24, 2017 7:24:19 GMT -5
Order one of these for Lot-O base. Check shipping costs first. Gotta read the fine print Mel. That is hifreakenlarious!!! Thanks for the laugh out loud moment.
Post by melhill1659 on Feb 24, 2017 7:30:25 GMT -5
Thanks Chuck now I have a picture in my head I can run with it.
ChicagoDave
Member since June 2016
Post by ChicagoDave on Feb 24, 2017 9:33:24 GMT -5
I would like to say again that placing the rubber mat between the blocks and my basement floor worked wonders to stop the "humming" sound from being annoying upstairs. Not sure if your workshop is detached from the house.
Post by captbob on Feb 24, 2017 9:58:28 GMT -5
Most people seem to have them mounted to a single concrete block but I like mine at work height so I used the 3 block method in the link below. Chuck I think she is only like 3 feet tall. One block should be work height.
Post by melhill1659 on Feb 24, 2017 10:45:11 GMT -5
Aren't you just the comedian today Capt'n 😜 I'm every in of 5' thankcha... my shop is away from the house ChicagoDave but since everybody stood in the corner snickering and left out I needed to buy one of them there flat pyramids to mount it on I've got to make some room for it 😂😂
Post by captbob on Feb 24, 2017 10:48:17 GMT -5
You be gonna needin' a bigger shed!
Post by captbob on Feb 24, 2017 10:50:20 GMT -5
Or just a second one of the same right next to the present one. Use one for the saws & tumblers and the other for your cabbing and whatever else you do. Lots of storage space that way.
Post by captbob on Feb 24, 2017 11:04:38 GMT -5
just thinkin'
I know you have that purdy Lortone 12 saw coming soon. Have you ever used a slab saw before? Asking because that oil mist from the saw is going to be a whole new game for you if you aren't used to it.
Post by Garage Rocker on Feb 24, 2017 11:46:33 GMT -5
You got the dually, huh? Gonna take a lot o material to keep that puppy fed. Great grab on the genie, surely your shopping list is dwindling.?
Post by captbob on Feb 24, 2017 11:48:48 GMT -5
With them dual barrel units, can you run just one?
Post by Garage Rocker on Feb 24, 2017 12:09:04 GMT -5
With them dual barrel units, can you run just one? It's my understanding that you at least need some ballast in the other barrel. River gravel, marbles, or something. I know Jeremy uses one of those, but that guy has access to plenty of material. txrockhunter?
Post by txrockhunter on Feb 24, 2017 13:45:20 GMT -5
If you want to keep the twins well fed, make sure you have plenty of tumbling capacity! I keep about 120 lb's of rock tumbling and produces just enough to keep these guys full! Many variables in there (size, hardness, pre-shaping, grit size, etc., etc.). You can put some small rough in one of the barrels, to smooth out for filler, if you only want to run 1 load. You do need to keep both full when running. Looks like you are setting up a great work space!!!!! Here's my Mounting Setup - Used some construction adhesive between the blocks and a little under the lot-o to assist the double sided tape. Never took the time to paint them. Jeremy
Post by Garage Rocker on Feb 24, 2017 14:00:14 GMT -5
25 lbs. keeps me hoppin', I'd have to hire staff at 120.
Post by captbob on Feb 24, 2017 14:01:18 GMT -5
120 lbs running? wow... I thought I was outta control with 90+ pounds running. Is there a thread of your rotary set up somewhere Jeremy? Love to see it!
Post by captbob on Feb 24, 2017 14:08:40 GMT -5
Can one barrel be filled with water just for the balancing weight?
Post by captbob on Feb 24, 2017 14:24:31 GMT -5
Ms. Mel - have you already glued the tumbler to a cinder block?
Post by jamesp on Feb 24, 2017 15:16:06 GMT -5
Oops, Lot-O can do a number on cheap concrete.
