Post by MrMike on Mar 20, 2017 5:34:35 GMT -5
Going thru too many blades on the HF tile saw. Any recommendations for a 7" blade that will last? Continuous, segmented or turbo rim? Thanks
Post by Peruano on Mar 20, 2017 6:58:48 GMT -5
MK 225 I believe its called the Red Devil. Its a porcelain blade and goes forever.
Post by wigglinrocks on Mar 20, 2017 9:57:46 GMT -5
MK 225 Hot Dog
Post by johnjsgems on Mar 20, 2017 11:55:24 GMT -5
MK225 Hot Dog also marketed by Barranca as the Agate Kutter. It is a tile blade but as said "porcelain blade" so has a different matrix and very high diamond content so cuts hard rock well. You can also use the MK/BD 303C blades which are available in .030" and .050". Standard tile blades have a very hard matrix so cut hard rock slowly and poorly but make excellent grinding wheels. Even in tile blades you can find a difference. MK tile blades cut tiles generally chip free while Home Depot Chinese blades chip like crazy.
Post by Drummond Island Rocks on Mar 20, 2017 12:07:17 GMT -5
MK225 Hot Dog also marketed by Barranca as the Agate Kutter. It is a tile blade but as said "porcelain blade" so has a different matrix and very high diamond content so cuts hard rock well. You can also use the MK/BD 303C blades which are available in .030" and .050". Standard tile blades have a very hard matrix so cut hard rock slowly and poorly but make excellent grinding wheels. Even in tile blades you can find a difference. MK tile blades cut tiles generally chip free while Home Depot Chinese blades chip like crazy. I know tile saws run at a much higher RPM. If I were to get an MK225 for my lapidary trim saw what RPM should I set it up to run to get the most out of it. Chuck
Post by MrMike on Mar 20, 2017 19:09:42 GMT -5
MK225 Hot Dog also marketed by Barranca as the Agate Kutter. It is a tile blade but as said "porcelain blade" so has a different matrix and very high diamond content so cuts hard rock well. You can also use the MK/BD 303C blades which are available in .030" and .050". Standard tile blades have a very hard matrix so cut hard rock slowly and poorly but make excellent grinding wheels. Even in tile blades you can find a difference. MK tile blades cut tiles generally chip free while Home Depot Chinese blades chip like crazy. Peruano, wigglinrocks, John - Sounds like what I need. Wally World has it online for $27.99. Thanks for the advice gents.
sphereguy
Hello all I've been lurking for months now
Member since March 2017
Post by sphereguy on Mar 20, 2017 20:59:34 GMT -5
Those hot dog blades are worth there weight in gold. I have used about fifteen of them. When there cashed from a tile project they go to the lapidary saw and will work until I completely wear off the diamonds.
Post by MrMike on Mar 21, 2017 5:40:40 GMT -5
Those hot dog blades are worth there weight in gold. I have used about fifteen of them. When there cashed from a tile project they go to the lapidary saw and will work until I completely wear off the diamonds. Thanks for the info
Post by Peruano on Mar 21, 2017 7:47:31 GMT -5
Just remember its s slotted blade (like many tile blades) and may be more of a finger grabber than a totally continuous blade. The slotted design might also not be the best for precise cuts of soft material. I've literally cut thousands of slabs with a 12" blade I bought for my slab saw. The slots may also warrant an adjustment in oil/coolant levels if they carry more to the work surface.
Post by wigglinrocks on Mar 21, 2017 9:51:18 GMT -5
The Hot Dog is slotted but the slots are pretty thin . I have been using one for awhile and not had any finger cutting issues . Not saying it couldn't happen but I think you would have to be more clumsy than me to cut your finger .
sphereguy
Post by sphereguy on Mar 22, 2017 23:11:48 GMT -5
Just to add a little more info on hot dog blades. Each one I use in a residential,commercial application. typically porcelain tile but granite marble or ceremic tile application. These blades only wear out at about the point I set over ten thousand square feet. That doesn't mean ten thousand cuts but a lot of cuts. When they are no longer are adequate for the job saw I use them at home cutting rocks and corners off of performs. When I said I wear the matrix of diamonds down to the sintered core I mean to the steel part of the blade. Unlike a continuous rim blade they can burn you if you put to much finger pressure on the bottom 3/4 inch of the blade. And they will take your fingernail away very rapidly as any diamond blade would. This is over 20 years of personal tile experience. Best advice on using them for rocks is don't go to fast. Take your time. Un like a lapidary saw that takes ten minutes you can make a cut in a couple of minutes. The slower you go the better the cut and less heat and the blade will cut for a long time.
Post by Fossilman on Mar 23, 2017 10:18:23 GMT -5
Yes sir the MK!!! Two thumbs up
