Post by HankRocks on Mar 29, 2017 17:05:37 GMT -5
The haul from 6 days of collecting, about 450 pounds 70% came from the Singleton Ranch Some selected large nodules from Singleton, most ranged from 1 to 3 inches Close up of the large Blue Agate. The color was nice and it has some black plume showing. I did find one small area about 3/4 mile from parking that had lots of this Blue just in much smaller nodules I think this is not working, don't see the pictures in the preview like the first one. H
Post by Toad on Mar 29, 2017 17:06:29 GMT -5
Nope, not working...
Post by HankRocks on Mar 29, 2017 17:10:46 GMT -5
aaaaarrrrhhhh!!!!!!
This is beyond frustrating!! I worked almost an hour following the instructions I put in a google doc the last time I did this and no luck.
H
Post by Sabre52 on Mar 30, 2017 8:28:18 GMT -5
Try photobucket. It''s so easy even I can use it. Should be a tutorial on here somewhere. That's how I learned to post pics.....Mel
Post by HankRocks on Mar 30, 2017 8:51:50 GMT -5
I gave up on Photobucket. Once the pictures were in it wasn't to difficult to get the correct link out. It was the Import process as the last two times I tried to load a couple of photos it took an hour and I never was successful, that included a reboot and the use of Task Manager. Flickr is much easier to import into, it's copying the super long string and editing it down to the exact string of characters required that is painful, an extra space here or character left there and the link is invalid, nothing shows up.
I suppose I may just look into setting up albums in Flickr and then just posting a link to those albums.
Post by Garage Rocker on Mar 30, 2017 9:07:55 GMT -5
Flickr is much easier to import into, it's copying the super long string and editing it down to the exact string of characters required that is painful, an extra space here or character left there and the link is invalid, nothing shows up. I think you may be making Flickr harder than it should be. Once you pull up the image you want to use, hit the little arrow share icon at the bottom right of your screen. Then you will see sharing options. Click the BBCode option and the whole code will be highlighted blue. Put your cursor in there and right click, then hit copy. Then come back here to your post and right click again. Hit paste and the whole string is inserted. That's it. Your image will appear when you hit create post. You can get a preview of it by hitting the BBCode tab at the bottom left of your screen here and then click back on the preview tab. Easy.
ETA: You can choose the image size before copying your BBCode.
Post by Fossilman on Mar 30, 2017 9:53:21 GMT -5
On photobucket I use their slide program only anymore....With Flickr,the photos come up much bigger and people like that also....
Post by HankRocks on Mar 30, 2017 10:44:15 GMT -5
Garage Rocker I just copied your message into my "Inserting Pictures" document in Google Docs. Will try it later.
Thanks
H
