Post by youp50 on Apr 5, 2017 16:54:11 GMT -5
Just poking around a catalog and I got to see the price of replacement barrel liners for the 40 lb Lortanes. If this applies to you, look into Flexane. Its to spendy to repair pvc barrels with, but well over a C note, you may be able to effectively repair the liner. I have applied a lot of it at an iron ore processing facility. Its like liquid hockey puck. You do need to get the primer. There is a blue and and orange. One is for steel then put on the 'other'. The 'other' is for rubber. Rubber only needs the 'other', steel needs both.
