Post by HankRocks on Apr 15, 2017 8:50:04 GMT -5
Any suggestion for type of 10 inch Diamond Blade to buy and where to buy it? It's for a RayTec 10 inch slab saw.
Thanks
H
Post by manofglass on Apr 15, 2017 8:55:19 GMT -5
Amazon.com Has a little of everything
Walt
Post by captbob on Apr 15, 2017 9:24:43 GMT -5
Truly only one place - johnjsgemswww.jsgemslapidary.comYes, sometimes it's a buck or two more than if you go on a search, but for a buck or two, I would much rather support an outstanding member here.
Post by Deleted on Apr 15, 2017 9:58:32 GMT -5
John would be my go to guy. He is a regular contributor here and just a super nice man.
Post by johnjsgems on Apr 15, 2017 10:45:53 GMT -5
Aw, shucks. I'm getting all misty. Thanks for the kind words. As far as which blade, if a power feed use .040" or thicker to avoid blade deflection while cutting. I personally like the 301 blades as they slice through the hardest rock without flinching but the 303C blades would serve you well for close to half price. If you are hand feeding and trimming the .032" saves material.
Post by roy on Apr 15, 2017 11:06:31 GMT -5
Aw, shucks. I'm getting all misty. Thanks for the kind words. As far as which blade, if a power feed use .040" or thicker to avoid blade deflection while cutting. I personally like the 301 blades as they slice through the hardest rock without flinching but the 303C blades would serve you well for close to half price. If you are hand feeding and trimming the .032" saves material. lol your always my first choice
Post by Sabre52 on Apr 15, 2017 13:42:48 GMT -5
Glad y'all reminded me. I just went and sent off for a new 303C from John. These are really good blades. I actually like them better than the 301. For me they seem to work better and the one I'm cutting agate with now has cut so long it's down to the last 1/8 inch of diamond. I had a 301 too, but to me, on my Covington, it seemed to require cleaning the oil far more often as it had a tendency to bog down in the cut. The 303C seems to still cut swell even when the oil is almost chocolate pudding. As you might surmise from this, the Covington is a bear to clean so I don't clean it often *L*.....Mel
Post by Deleted on Apr 16, 2017 13:18:27 GMT -5
Glad y'all reminded me. I just went and sent off for a new 303C from John. These are really good blades. I actually like them better than the 301. For me they seem to work better and the one I'm cutting agate with now has cut so long it's down to the last 1/8 inch of diamond. I had a 301 too, but to me, on my Covington, it seemed to require cleaning the oil far more often as it had a tendency to bog down in the cut. The 303C seems to still cut swell even when the oil is almost chocolate pudding. As you might surmise from this, the Covington is a bear to clean so I don't clean it often *L*.....Mel Mel, i too have a Covington. You have mentioned many issues and this particular one makes me think your saw feeds too fast. Mine too! Covington seems to have made their feed rates very high. I am buying new pulleys to slow the feed down.
Post by johnjsgems on Apr 17, 2017 12:33:05 GMT -5
I think the 10" has a motor feed not belts. I briefly had an 8" Covington that someone had cut out the sump divider. That would make the saw much easier to clean.
70karmann
Member since February 2011
Post by 70karmann on Apr 20, 2017 18:19:03 GMT -5
J S Gems for all my blades. Great service.
Post by Sabre52 on Apr 20, 2017 19:51:27 GMT -5
Just got my new blade from John in today's mail. Five days, very fast, and great pricing too. Thanks John!!!!
Now I just have to make myself clean the dang saw *L*...Mel
