Post by Peruano on Apr 23, 2017 17:26:39 GMT -5
I initially cleaned pretty thoroughly, but now just get as much liquid and solids out as possible, use cleaner oil to wash down the vice and rails, and refill. The bit of discolored oil and minor amount of grit left in the saw just shorten the time till the next cleanout by a day or two so . . . . It may feel good to start with a cleaner saw but after a day of cutting they all look the same.
Post by Sabre52 on Apr 23, 2017 18:37:02 GMT -5
I run my saw till the oil looks like chocolate puddin and you can barely see the saw, then clean the sludge, wipe it down and refill...Mel
cabjunky
Regency Rose Plume
Member since November 2008
Post by cabjunky on Apr 23, 2017 21:06:14 GMT -5
I clean mine out when the gunk starts adhearing to the lid and carriage. I dont go as far as using degreaser, but i do wipe everything down after I've removed the used oil. I especially make sure the carriage is clear of all debris prior to adding fresh oil.
Post by Fossilman on Apr 23, 2017 22:29:20 GMT -5
I clean mine like its never seen oil,than start fresh.......
sphereguy
Hello all I've been lurking for months now
Member since March 2017
Post by sphereguy on Apr 24, 2017 2:17:34 GMT -5
On my saws I clean every third or fourth oil change. By clean I mean. Empty and squeegee the bottom and white terry cloth everything. Pure clean oil over all moving parts. . It never hurts to check nuts an bolts and bearing rollers to insure alignment and carriage is functioning. Some times it's only a couple weeks between clean outs. Lots of slabs, and preforms to cut.
Post by MrP on Apr 24, 2017 4:40:16 GMT -5
Dip out most of the sludge. I have a double pail with paper bag for filtering the old oil. Refill with oil. Start cutting! Why waste time cleaning when it will be dirty on the first cut anyway.............................................MrP
Erich
Member since November 2015
Post by Erich on Apr 24, 2017 6:09:15 GMT -5
Squeaky clean for me. Field Day deeply ingrained...
