itsandbits
Member since March 2012
Post by itsandbits on Jun 23, 2017 22:50:44 GMT -5
Post by Deleted on Jun 24, 2017 0:45:31 GMT -5
Looks like granite to me. That one tan squarish crystal looks like plagioclase feldspar
metalsmith
Post by metalsmith on Jun 24, 2017 1:13:58 GMT -5
Looks like granite to me. That one tan squarish crystal looks like plagioclase feldspar Yeah but... It appears to have broadly rectangular cleavage suggesting (if it were feldspar) orthoclase; pink colouration: plagioclase Likely real-world facts: somewhere between the two Rhodonite? The jury is out. More images / info required. Lovely cab all the same!
itsandbits
Post by itsandbits on Jun 24, 2017 2:36:55 GMT -5
Post by pghram on Jun 24, 2017 6:54:54 GMT -5
Beautiful cab from some real interesting material.
Peace, Rich
Post by rockjunquie on Jun 24, 2017 7:33:53 GMT -5
I seem to have a problem viewing your images. I couldn't see the posted pic of the wire wrapped piece in the other thread, either.
itsandbits
Post by itsandbits on Jun 24, 2017 9:33:40 GMT -5
I seem to have a problem viewing your images. I couldn't see the posted pic of the wire wrapped piece in the other thread, either. I'm sorry; I would find that annoying too, what does it do when you click the link just above the picture?
Post by rockjunquie on Jun 24, 2017 9:37:26 GMT -5
I seem to have a problem viewing your images. I couldn't see the posted pic of the wire wrapped piece in the other thread, either. I'm sorry; I would find that annoying too, what does it do when you click the link just above the picture? I can see the images at the link. I can't see the embedded images. There's just a big minus sign where a picture should be. I wouldn't say I'm annoyed and I am sure it is not your fault. Just letting you know. The stone at the link doesn't look a whole lot like rhodonite I've seen, but it could just be the picture or lighting.
Post by Deleted on Jun 24, 2017 10:16:14 GMT -5
Does it scratch with a knife?
itsandbits
Post by itsandbits on Jun 24, 2017 10:46:28 GMT -5
Does it scratch with a knife? nope, and it's def not feldspar, lots of that around too
itsandbits
Post by itsandbits on Jun 24, 2017 10:49:48 GMT -5
I'm sorry; I would find that annoying too, what does it do when you click the link just above the picture? I can see the images at the link. I can't see the embedded images. There's just a big minus sign where a picture should be. I wouldn't say I'm annoyed and I am sure it is not your fault. Just letting you know. The stone at the link doesn't look a whole lot like rhodonite I've seen, but it could just be the picture or lighting. There's quite a bit of it in BC, Most of BC is accreted ocean bed and islands with a lot of mineralization from sea creatures to volcanics
metalsmith
Post by metalsmith on Jun 24, 2017 14:04:46 GMT -5
i'm not seeing embedded images either. However your photo does look a lot more like rhodonite than before and guess what ... ... It has a perfect, prismatic cleavage, almost at right angles. So there you go! I know that it is found in the area, so apologies if we rubbed you up the wrong way and you knew all along?! But the first image just didn't look the part.[/quote]
Post by Deleted on Jun 24, 2017 14:38:38 GMT -5
itsandbits
Post by itsandbits on Jun 24, 2017 16:50:37 GMT -5
i'm not seeing embedded images either. However your photo does look a lot more like rhodonite than before and guess what ... ... It has a perfect, prismatic cleavage, almost at right angles. So there you go! I know that it is found in the area, so apologies if we rubbed you up the wrong way and you knew all along?! But the first image just didn't look the part. [/quote] No probs, Iknow what it is and I don't mind questions anyway, I don't know a lot about a lot of things so if someone can prove me wrong or we just can't agree, that's fine :-)
itsandbits
Post by itsandbits on Jun 24, 2017 16:58:21 GMT -5
as it degrades/changes, it turns intothis material which I have seen the name for but can't remember. I'ts in the same slide. brecciated but very solid goo.gl/photos/vQV2DwuLegvcUc7S6
