jeannie
Member since January 2017
Post by jeannie on Jun 25, 2017 10:59:46 GMT -5
Scott is almost finished with my cab machine! I'm so excited to get to work on it soon! He has done an amazing job, and I very much appreciate all of the time and effort he has put into this for me!💕@shotgunner
Post by wigglinrocks on Jun 25, 2017 13:30:04 GMT -5
Very well done to this point . I like the jugs , no rust and a big drain . Might need a touch of purple paint on them .
Post by jamesp on Jun 25, 2017 14:20:32 GMT -5
Dito the jugs. Right up Scott's alley. What a clean build. Trademark purple. Looks inviting. Well done Mr. Solar.
Post by Deleted on Jun 25, 2017 14:33:07 GMT -5
Thanks guys. I got the jugs idea from ziggy's hubby. Not my idea at all. Only comes in blue, in this shape. Polyethylene won't take paint sorry... I'm down to niggling bits. Finalizing the returns into the bucket and wire it up. Should have it it running today, although it's Africa hot here at the moment. 15-30 minutes work between breaks. Tommy (when he returns from rockhounding) rockjunquie
jeannie
Post by jeannie on Jun 25, 2017 14:56:08 GMT -5
Update: Here you can see his smartly engineered plumbing system better! Just electrical left! Yay!!!😊😍😊
Post by rockjunquie on Jun 25, 2017 15:09:29 GMT -5
That came out GREAT!!!! I love the spacing between the wheels. You will love that, jeannie! This will have to be moved, of course. I'll let Tommy decide- DIY Tutorial Cabbing section or DIY tool section.....
Post by Deleted on Jun 25, 2017 15:11:09 GMT -5
I'm probably 30 minutes from done assembling. Then add water to the bucket, flip the switch and break down the DP stippling on the wheels.
Post by Deleted on Jun 25, 2017 15:21:02 GMT -5
Getting serious!!! I posted this one cuz it scared jeannie!
Post by orrum on Jun 25, 2017 16:35:51 GMT -5
Scott u got skilz boyo, I am impressed!##
ziggy
Member since June 2016
Post by ziggy on Jun 25, 2017 16:57:30 GMT -5
Update: Here you can see his smartly engineered plumbing system better! Just electrical left! Yay!!!😊😍😊 Looks a lot like mine. Our water supply has individual shut off valve for each wheel. That way we only need one wheel getting soaked at a time. The valves also can adjust the flow to supply only the water desired. Don't forget to mount some sort of spray stopper over the wheels. We just use some denim strips. The rock snot is getting thick on ours. Good thing clean up is so easy.
Post by MrMike on Jun 25, 2017 17:08:21 GMT -5
Really cool jeannie, Scott has done a great job. One thing though, tell him you want all sintered diamond wheels, they aren't that much $....
Post by rockjunquie on Jun 25, 2017 18:01:51 GMT -5
The only thing I can see wrong with that beauty is that it's too clean. jeannie, I'm counting on you to dirty it up and don't forget to show off those cabs!
Post by Deleted on Jun 25, 2017 18:42:06 GMT -5
Really cool jeannie, Scott has done a great job. One thing though, tell him you want all sintered diamond wheels, they aren't that much $.... Thanks Mike. It's fun to make stuff. She will likely replace these wheels with sintered as they need replacing. Parts are on her. I just did the build! As it is this machine is approximately $900 inclusive. Labor was her birthday gift.
Post by Deleted on Jun 25, 2017 18:44:37 GMT -5
Update: Here you can see his smartly engineered plumbing system better! Just electrical left! Yay!!!😊😍😊 Looks a lot like mine. Our water supply has individual shut off valve for each wheel. That way we only need one wheel getting soaked at a time. The valves also can adjust the flow to supply only the water desired. Don't forget to mount some sort of spray stopper over the wheels. We just use some denim strips. The rock snot is getting thick on ours. Good thing clean up is so easy. Of course it does. I stole the idea from you!! Ha! I'm running a recirculation system.for the water. All wheels will be wet. Pump wired to the same switch as the motor. If needed I will put a denim curtain to retard splashing. Thanks Ziggy
jeannie
Post by jeannie on Jun 25, 2017 19:23:50 GMT -5
The only thing I can see wrong with that beauty is that it's too clean. jeannie, I'm counting on you to dirty it up and don't forget to show off those cabs! I will definitely share pictures of me using it and some finished cabs!😊
jeannie
Post by jeannie on Jun 25, 2017 19:25:21 GMT -5
It got up to 104 degrees here today. We had to take a break for a while, and now we're finishing!!!
Post by rockjunquie on Jun 25, 2017 19:35:50 GMT -5
BTW- I have to add that I love the colors. That table is so bight and happy. God I love purple.
notjustone
Post by notjustone on Jun 25, 2017 19:47:17 GMT -5
might want to leave the denim off till it cools down that water mist might be refreshing in that heat.
Post by Pat on Jun 25, 2017 21:32:22 GMT -5
Wow!
Post by Deleted on Jun 25, 2017 21:38:21 GMT -5
BTW- I have to add that I love the colors. That table is so bight and happy. God I love purple. Yeah, I'm a little obsessed with purple too. Lol The water jug shields are only that color. So for the fabric water splash guards jeannie intends to make "curtains" to tie it all together. Haha
