gemfeller
Member since June 2011
Post by gemfeller on Jul 4, 2017 23:07:05 GMT -5
metalsmith
Post by metalsmith on Jul 5, 2017 0:37:26 GMT -5
That's great ... though I don't think DeBeers have anything to fear. We already have synthetic diamonds.
Post by fantastic5 on Jul 5, 2017 7:51:05 GMT -5
Very interesting! Watched the whole video. I bet these little buggers are pretty expensive to create at this point.
Post by Deleted on Jul 5, 2017 10:15:41 GMT -5
They don't explain the electricity producing chemistry.
Post by Deleted on Jul 5, 2017 10:25:46 GMT -5
I guess that the c14 decay releases a beta particle and that becomes current?
gemfeller
Post by gemfeller on Jul 5, 2017 12:28:53 GMT -5
I guess that the c14 decay releases a beta particle and that becomes current? This is a pretty general article and I suspect a little sensationalism on the part of the author(s). It'll be interesting to see if the technical journals follow up with more specific info about the processes involved and the electrical generation aspect. I'd also be interested to learn how this diamond-making process specifically relates to current methods of diamond synthesis. It appears to be similar to the chemical vapor deposition (CVD) method now in widespread use.
gemfeller
Post by gemfeller on Jul 5, 2017 12:32:49 GMT -5
That's great ... though I don't think DeBeers have anything to fear. We already have synthetic diamonds. Re: DeBeers. Sometimes you Brits just don't "get" our subtle Yankee humor.
Post by vegasjames on Jul 5, 2017 18:45:09 GMT -5
I guess that the c14 decay releases a beta particle and that becomes current? Could be along those lines. That is similar to the Nucell battery, which used a beta source to generate electricity.
Post by vegasjames on Jul 5, 2017 18:50:29 GMT -5
Very interesting! Watched the whole video. I bet these little buggers are pretty expensive to create at this point. Diamond is not that expensive to produce with the new technologies. In the early days when GE started producing diamonds the cost was more than that of naturally occurring diamonds. But Gemesis is supposedly producing gem quality diamonds for about $5 a carat. Not sure on the cost of chemical vapor deposition diamonds, but the raw materials are very inexpensive. And there are several ways of doing this. Originally they were using heated tungsten coils to knock the carbon out of methane. Then they went to a microwave beam and now I think they are using a laser to do the same thing. But CVD produces diamond coatings microns at a time.
gemfeller
Post by gemfeller on Jul 5, 2017 19:44:19 GMT -5
Post by Deleted on Jul 5, 2017 19:51:57 GMT -5
I will read your link later. Thanks!
I wonder what electric energy density is?
ETA
Forbes is awesome.
15 joules per gram. A kilogram will produce some little bit more than a AA battery
Post by vegasjames on Jul 5, 2017 20:18:06 GMT -5
This will explain the principle of how the beta particles produce electricity: www.rexresearch.com/nucell/nucell.htmThe Nucell battery is also significantly more powerful. A soup can sized battery produces 75 watts as where a small barrel size 30 inches tall produces 100 kilowatts. I heard there were supposed problems with corrosion, which does not make a lot a sense. But I also heard the military is using the same exact technology so it sounds more like they just did not want a cheap energy source on the market competing with the power companies.
