sschus87
Member since November 2015
Post by sschus87 on Jul 25, 2017 16:21:27 GMT -5
Picked this up the other day at Lowe's. 10 ft. 1/2" ID hose. Perfect for using on my tumblers. They had red hose which was $18 and the green was on clearance for $4.99. Guess which I bought? Maybe if someone needs some they will have it at the Lowe's near you. Good luck!! Thanks---Steve
Post by captbob on Jul 25, 2017 17:33:40 GMT -5
uh... just how do you use this with a tumbler?
unclesoska
Member since February 2011
Post by unclesoska on Jul 25, 2017 19:19:05 GMT -5
Great minds thinking alike- I've used the red hose on my QT6 rollers- works great! Good call!
salpal48
Member since March 2015
Post by salpal48 on Jul 25, 2017 19:44:33 GMT -5
I have used that Hose to Recover some shafts. But There is a Lot of leeway in there 1/2". If your shaft is .500-.502 they are Loose. But some are .510 They will fit better. If you bring the shaft to the store and try different one's You will get a Better fit
Post by Deleted on Jul 25, 2017 20:10:34 GMT -5
Why do you cover the shafts?
ETA
Lowe's is a fantastic #2.
sschus87
Post by sschus87 on Jul 25, 2017 22:45:47 GMT -5
I have used that Hose to Recover some shafts. But There is a Lot of leeway in there 1/2". If your shaft is .500-.502 they are Loose. But some are .510 They will fit better. If you bring the shaft to the store and try different one's You will get a Better fit I wish I had a little more leeway. I cut the hose to length and pounded the crap out of my shaft (heard it when I said it) and couldn't get the hose on all the way. I finally cut it off and cut another piece and put it in boiling water for a couple of minutes to soften it up. It finally slid on. It wasn't easy, and I have blisters on both hands to prove it. Not from the heat of the hose, but from the repetitive motion of trying to pound the hose on the shaft.
sschus87
Post by sschus87 on Jul 25, 2017 22:51:02 GMT -5
Why do you cover the shafts? ETA Lowe's is a fantastic #2. It provides grip for the barrels. My old shaft covering had worn out completely. Also, I went to my local metal shop (Alro Steel in Jackson, MI.) and they cut 2 1/2" shafts (cold rolled) to length for me and the total cost was $4.51. I couldn't complain about that!!
sschus87
Post by sschus87 on Jul 25, 2017 22:52:07 GMT -5
uh... just how do you use this with a tumbler? Pictures posted in thread to show how I used these... Thanks---Steve
Post by quartz on Jul 25, 2017 22:55:19 GMT -5
I lube the rods with a light coat of vegetable oil, seems to slip better than when water-wet from a hot water soak.
Post by MrP on Jul 26, 2017 4:07:46 GMT -5
Why do you cover the shafts? ETA Lowe's is a fantastic #2. It provides grip for the barrels. My old shaft covering had worn out completely. Also, I went to my local metal shop (Alro Steel in Jackson, MI.) and they cut 2 1/2" shafts (cold rolled) to length for me and the total cost was $4.51. I couldn't complain about that!! I put 2" wide Gorilla Tape on the shafts of those type of tumblers but on my big one that has 3/4" shafts I put couple of wraps on the barrels themselves. Those barrels don't like metal to metal so the tape takes care of that. I have hade the tape last over a year running 24/7. Cheap and effective............................MrP
sschus87
Post by sschus87 on Jul 26, 2017 9:36:27 GMT -5
I put 2" wide Gorilla Tape on the shafts of those type of tumblers but on my big one that has 3/4" shafts I put couple of wraps on the barrels themselves. Those barrels don't like metal to metal so the tape takes care of that. I have hade the tape last over a year running 24/7. Cheap and effective............................MrP Never thought of that. I have used electrical tape, with little success. Maybe I should have asked on here before I put myself through the trouble of redoing these... Thanks---Steve
Post by Deleted on Jul 26, 2017 10:26:50 GMT -5
The shafts on my tumbler has n coverings. Spins the barrels well. jamesp uses bare steel also. I learned it from him.
Post by johnjsgems on Jul 26, 2017 10:33:53 GMT -5
I don't know how price compares but you can buy "Tygon" tubing by the foot at Home Depot and I assume Lowes. It is a clear to milky white tubing with braided reinforcement. Buy as many feet as you need.
Post by MrP on Jul 26, 2017 12:04:17 GMT -5
The shafts on my tumbler has n coverings. Spins the barrels well. jamesp uses bare steel also. I learned it from him. My shaft has no covering either. Didn't do it for traction did it to stay away from metal to metal...............................MrP
