Post by RWA3006 on Aug 13, 2017 17:43:45 GMT -5
That is a great idea Henry. I wonder if the plastic will quiet it down as well. You inspired me to try 1/8" rubber gasket material. I've seen it at Ace Hardware.
Post by HankRocks on Aug 27, 2017 12:09:06 GMT -5
Finally got the Super Grinder built. Found some thin wall plastic tubing that fit as bushing material perfectly. One thing for sure, the super-Grinder is a Super Grinder! It is a bit rough which is what I expected. There is a little belt slipping on some of the soft areas which a slight belt tightening should cure. It took the back off of a couple of small botryoidal pieces from Singleton in short order exposing some nice Bouquet underneath. It's a bit messy, with tiny pieces bouncing everywhere.
Henry
