kevin24018
Member since February 2012
Post by kevin24018 on Aug 6, 2017 14:23:44 GMT -5
This was the plastic from a poster frame. It's a little too wide for comfort but it works like I hoped. flic.kr/p/XtprMPflic.kr/p/Xtps8Dflic.kr/p/XtpterI notched the ends and reinforced the edges with duct tape. It came with a plastic film that you are supposed to remove, I left it on for protection. I considered putting plastic wrap on it to help with scratches but I don't think I'll need to worry about it.
Post by manofglass on Aug 6, 2017 16:35:27 GMT -5
You need that because
Walt
Post by MrMike on Aug 6, 2017 16:51:13 GMT -5
That's cool kevin24018, just a little wide in my opinion, be hard to reach around.
Post by manofglass on Aug 6, 2017 17:22:42 GMT -5
Sabersaw cuts plastic
Walt
Post by wigglinrocks on Aug 6, 2017 18:07:12 GMT -5
Good idea , beats wearing an apron
Post by jamesp on Aug 6, 2017 18:50:40 GMT -5
Post by aDave on Aug 6, 2017 20:25:32 GMT -5
Let me be the naysayer in this thread. Instead of using a shield, go to the backside of the saw and pull instead of push. A little bit of misting occurs, but it's not daunting. Hell, on a hot day, it feels pretty good.
ETA: Today, as like the two previous days, I spent about two hours cutting on each day. T-shirt was a bit wet, but I didn't need to change it at the end of the day. If I was standing in front of the saw, I'd be looking for a shield. Standing on the backside doesn't produce any issues whatsoever..
Dave
Post by jamesp on Aug 6, 2017 21:58:43 GMT -5
Let me be the naysayer in this thread. Instead of using a shield, go to the backside of the saw and pull instead of push. A little bit of misting occurs, but it's not daunting. Hell, on a hot day, it feels pretty good. ETA: Today, as like the two previous days, I spent about two hours cutting on each day. T-shirt was a bit wet, but I didn't need to change it at the end of the day. If I was standing in front of the saw, I'd be looking for a shield. Standing on the backside doesn't produce any issues whatsoever.. Dave Rock doesn't care which way it approaches the blade. Feed conservatively and all goes well. Good post adave
kevin24018
Post by kevin24018 on Aug 7, 2017 7:53:07 GMT -5
Let me be the naysayer in this thread. Instead of using a shield, go to the backside of the saw and pull instead of push. A little bit of misting occurs, but it's not daunting. Hell, on a hot day, it feels pretty good. ETA: Today, as like the two previous days, I spent about two hours cutting on each day. T-shirt was a bit wet, but I didn't need to change it at the end of the day. If I was standing in front of the saw, I'd be looking for a shield. Standing on the backside doesn't produce any issues whatsoever.. Dave I've done that, still very messy. Does your saw have a fence? I took mine off and I use a lot of water. The shield keeps me much cleaner that w/o it. This tile saw really slings the water high and far.
kevin24018
Post by kevin24018 on Aug 7, 2017 7:55:41 GMT -5
That's cool kevin24018, just a little wide in my opinion, be hard to reach around. it is, although I can reach around it, it will be more comfortable for me if it's not as wide. I just score it deeply with a utility knife and break it. I'll work on it some more.
Post by aDave on Aug 7, 2017 11:53:45 GMT -5
Let me be the naysayer in this thread. Instead of using a shield, go to the backside of the saw and pull instead of push. A little bit of misting occurs, but it's not daunting. Hell, on a hot day, it feels pretty good. ETA: Today, as like the two previous days, I spent about two hours cutting on each day. T-shirt was a bit wet, but I didn't need to change it at the end of the day. If I was standing in front of the saw, I'd be looking for a shield. Standing on the backside doesn't produce any issues whatsoever.. Dave I've done that, still very messy. Does your saw have a fence? I took mine off and I use a lot of water. The shield keeps me much cleaner that w/o it. This tile saw really slings the water high and far. Are you referring to a fence or blade guard? If you removed the guard, I can see where that could make things a bit messier for you. My blade guard is still on the saw. Dave
kevin24018
Post by kevin24018 on Aug 7, 2017 12:25:34 GMT -5
I've done that, still very messy. Does your saw have a fence? I took mine off and I use a lot of water. The shield keeps me much cleaner that w/o it. This tile saw really slings the water high and far. Are you referring to a fence or blade guard? If you removed the guard, I can see where that could make things a bit messier for you. My blade guard is still on the saw. Dave yeah meant the blade guard, took that off, they aren't useful for rocks and rather flimsy, not to mention I cut bigger rocks than I should, but gotta make due with what ya have.
