lancemountain
Member since March 2017
Post by lancemountain on Aug 19, 2017 20:55:40 GMT -5
I have two now and would like to organize my basement. Would running two lortone 33b's off of a power strip be ok?
Post by wigglinrocks on Aug 19, 2017 21:00:05 GMT -5
Yes it would be fine , the small lortones don't draw much juice .
Post by manofglass on Aug 19, 2017 21:01:11 GMT -5
Run it a few hours then grab the power strip Cord see if it is hot
Walt
Post by aDave on Aug 19, 2017 21:12:37 GMT -5
Run it a few hours then grab the power strip Cord see if it is hot Walt In my experience, it is not the cords that are the issue. It's the connections at all of the sockets that cause heat degredation. I've seen plenty of power strips that are discolored by heat near the sockets. The cords are not the promlem. Dave
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Aug 19, 2017 23:03:53 GMT -5
I have Lortone QT66 and 3B tumblers, together they pull a total of 77 watts. Theoretically you could run 31 times that amount of power on a regular 2400 watt household outlet provided the powerstrip was using 12ga wire to the plug.
lancemountain
Post by lancemountain on Aug 20, 2017 0:30:03 GMT -5
ok thank you Gents!
Post by orrum on Aug 20, 2017 7:52:22 GMT -5
I use them so I can switch the tumblers off easy.
Post by fernwood on Aug 20, 2017 8:17:05 GMT -5
A lot depends on the capabilities of the circuit and power draw. How many amps is it? Identify what other items are on the same circuit. Also suggest a fused power strip.
Yes, check for warmth.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on Aug 20, 2017 8:27:31 GMT -5
I am fairly sure that all powerstrips have a builtin circuit breaker for overload protection
zekester55
Post by zekester55 on Aug 22, 2017 5:27:07 GMT -5
Check out my 13 August post here: Not burning the house down
I've got 3 tumblers, two LED strip lights and two muffin fans running of that power strip, That's been going for months, no issues at all.
huskeric
Member since May 2016
Post by huskeric on Aug 23, 2017 11:34:47 GMT -5
I run mine on a power strip, and I go one further. I bought some plug switches so that I can just toggle my tumblers on/off instead of unplugging them. They're about $3 each on Amazon.
Post by spiceman on Aug 23, 2017 16:53:32 GMT -5
I like that switch idea, will check out plug switches. Cheap too.
