Post by jamesp on Nov 15, 2017 9:06:21 GMT -5
I rubbed this tumble on 80 grit sandpaper for 3 minutes. kk, probably some fine carving stone.
Post by kk on Nov 15, 2017 10:01:07 GMT -5
Sounds like easy to carve, but will it hold edges all the way to polish? Material looks similar to Tianhuang Jade, highly valued in China and which is actually a serpentine soapstone mixture.
Post by jamesp on Nov 15, 2017 16:18:09 GMT -5
Sounds like easy to carve, but will it hold edges all the way to polish? Material looks similar to Tianhuang Jade, highly valued in China and which is actually a serpentine soapstone mixture. I believe is serpentine with a degree of silica well blended. Sure holds up in the tumbler well. I would consider it with strong mechanical properties. Dense. I believe it is from China.
georgeb138
Member since April 2017
Post by georgeb138 on Nov 15, 2017 19:38:29 GMT -5
Neat stuff. Going to try to shine it up manually?
Post by jamesp on Nov 16, 2017 5:19:19 GMT -5
Neat stuff. Going to try to shine it up manually? I should try. Rubbing it on a wet wash cloth laced with aluminum oxide polish should get the job done. I have some Linde 50,000 if I can find it.
georgeb138
Post by georgeb138 on Nov 17, 2017 19:50:59 GMT -5
Neat stuff. Going to try to shine it up manually? I should try. Rubbing it on a wet wash cloth laced with aluminum oxide polish should get the job done. I have some Linde 50,000 if I can find it. I've never heard of that method before. Interesting.
Post by jamesp on Nov 18, 2017 2:22:05 GMT -5
I should try. Rubbing it on a wet wash cloth laced with aluminum oxide polish should get the job done. I have some Linde 50,000 if I can find it. I've never heard of that method before. Interesting. Or Dawn dish wash soap instead of water
