tropidale
Member since October 2016
Post by tropidale on Dec 7, 2017 0:17:08 GMT -5
I am thinking of moving to a smaller true lapidary trim saw hoping for a more precise, quieter and less drenching experience than my tile saw and noticed something in my shopping.
It appears that most trim saws are set up for right-handed people with the larger portion of the table to the right. Yes? I hold the slab with my left hand typically and it doesn't look like there is a lot of room to do that on the smaller saws.
Any lefties out there with experience with the smaller saws? Is it as tight a space as it looks? I have pretty small hands but would still like enough table space to maneuver a 5-6 inch slab. I can do some things right handed but sawing feels much better controlled with my left.
I have read several comments about pulling the slab through the blade from the back to avoid the bath. That would actually put the larger side on my left where I would prefer it. But would that be doable with a trim saw style? Haven't tried it yet on my tile saw.
It isn't easy being a lefty in a right-handed world!
Recommendations?
Thanks,
Dale
Post by Pat on Dec 7, 2017 0:41:29 GMT -5
Place a splash guard between you and the saw blade to stay dry. I just stuck an upright slab on the edge. Works well.
Don't know about left hand anything.
Post by rmf on Dec 7, 2017 5:38:03 GMT -5
tropidale, I am left handed and for years I have used a Lortone saw. The one I use is the discontinued Hi-ball which was identical to the FS6 (also discontinued) they just had different pulley systems. They now appear to have dropped the 6" trim saws in favor of a 8" trim saw. FS8 Stainless Basic The basic unit without blade, motor, vise or hood. Can be fitted with any 8” blade (w/ 5/8” arbor hole). Requires 1/3 hp motor. Shipping weight 18 lbs. #056-292 This has a big table and and equally big tank down below. I prefer the big tank for oil since I am lazy and do not like to clean it out often. BTW you can put an 6" blade on this saw. they also have a more complete model FS8-C Stainless Steel Package Now available in stainless steel, this 8” saw is perfect for those desiring the capacity of a larger saw in an easy-to-clean design. We made the work table larger and kept the removable coolant pan. Includes vise, hood, 1/3 hp motor, and equipped with an 8” diamond blade with 5/8” arbor hole. Requires 41/2 quarts of cutting oil. Ships in three boxes. Package Dimensions: (1) 30” x 23” x 14” 44 lbs, (1) 18” x 16” x 6” 4 lbs., (1) 14” x 11” x 12” 19 lbs. Total Shipping weight 67 lbs. #056-293 This has the motor, a clear plastic hood with arm holes and a vise. (IMHO the vise is not worth anything) The clear plastic cover gets messy and makes it hard to see with oil and rock bits so I prefer just the splash screen in fromt. If I am doing a lot of trimming I still get covered to my elbows or higher with oil spray. BTW I need a new motor for my saw it is limping along but I have had it for 25 or 30 years and so far all I have replaced is blades but the motor will be coming up. Also for full disclosure we are Lortone dealers.
minerken
Member since August 2013
Post by minerken on Dec 7, 2017 14:29:30 GMT -5
the rock rascal is wider on the left but the table is smaller than the lortone over all
tropidale
Post by tropidale on Dec 7, 2017 18:19:39 GMT -5
Thanks, everybody. I think I am going to try the pull technique on my tile saw this weekend. If that works well, then maybe I will be happy to have a new "righty" trim saw. Of course now, I am trying to decide if I prioritize the trim saw or a new 150-600 mm lens I have had my eye on. I'm torn. Too many costly hobbies...
Thanks again.
Dale
