Post by Peruano on Dec 15, 2017 13:08:31 GMT -5
These two photos are merely the same photo turned upside down, but the perspective changes the total effect for my eyes most of the time. The original rock formation was a series of eroded holes in a vertical rock face in Baja California, Mexico. Do you see what I see?
Post by Pat on Dec 15, 2017 13:35:46 GMT -5
Yes, did you flip the negative over?
Interesting.
Post by Peruano on Dec 15, 2017 14:13:56 GMT -5
No, it was unnecessary to flip the negative. The original B&W print produced the flip when rotated 180 degrees. Its a matter of the shading and what side of the concavity its viewed from. Alas I don't recall what kind of rock it was.
Post by stephan on Dec 18, 2017 11:09:59 GMT -5
That looks like tafoni, which is granular rock, eroded by the wind. It is often seen near the coast, and I've seen it most often in sandstone.
Post by 1dave on Dec 18, 2017 11:37:06 GMT -5
i have the same problem with images like this - McDowell and Barnes Buttes in Phoenix. Are the dark places high or low?
Post by HankRocks on Dec 18, 2017 14:24:00 GMT -5
The dark areas are shadows cast by higher points of elevation blocking the sun.
Post by 1dave on Dec 18, 2017 19:47:07 GMT -5
The dark areas are shadows cast by higher points of elevation blocking the sun. Yeah but sometimes they look reversed.
Post by HankRocks on Dec 18, 2017 20:49:11 GMT -5
Suppose I need to get Google Earth Pro. After every rock collecting trip I go to Google Maps - Satellite View and scope out the area I was in. Good to study the terrain where the rocks were and what I may have missed or interesting to-be-explored areas in the future. One can see changes in surface where agates occur from where they do not. It is somewhat of a challenge as I do not have a Smartphone so I do not have co-ordinates to find the area. Studied the terrain on Singleton Ranch for quite a while and I have a good idea where I am headed once my feet hit the ground, unfortunately may never have a chance to test out my advanced scouting if the Ranch is shut down for collectors.
Post by jamesp on Dec 19, 2017 8:07:33 GMT -5
Topography photos will confuse for this reason 1dave.
