Member is Online
Post by jamesp on Dec 30, 2017 13:37:39 GMT -5
Check this goof up. I forgot to turn the burner off. Set at ~400F. Nice neat melt down. youp50
Post by captbob on Dec 30, 2017 13:45:49 GMT -5
Line the inside with some kinda foam and it would make a nice drink holder.
All sorts of uses for that!
Does it smell when it melts?
Post by manofglass on Dec 30, 2017 13:49:43 GMT -5
Just recut it on a wood lathe
Walt
Post by youp50 on Dec 30, 2017 13:59:42 GMT -5
The 100k machines just bring the faced pipe to the heater plate, not keep a steady pressure on it. The pressure is maintained during the fusion process. It appears to me that you had hired me to do that one. I tend to agree with Walt, except any method you have at your disposal would work. Personally, considering its a free scrap, I would put it in a prominent place as a reminder what not to do.
Post by captbob on Dec 30, 2017 14:06:20 GMT -5
I would put it in a prominent place as a reminder what not to do. I have had a spent shotgun shell on my desk for exactly that same reason. Smile every time I see it. Long story... cost me a couple hundred bucks, but a good lesson learned.
Post by youp50 on Dec 30, 2017 15:24:04 GMT -5
I would put it in a prominent place as a reminder what not to do. I have had a spent shotgun shell on my desk for exactly that same reason. Smile every time I see it. Long story... cost me a couple hundred bucks, but a good lesson learned. At least the burst barrel didn't connect with any flesh.
Member is Online
Post by jamesp on Dec 30, 2017 15:37:46 GMT -5
Line the inside with some kinda foam and it would make a nice drink holder. All sorts of uses for that! Does it smell when it melts? In this case it did put out some smell. But not any smoke. I believe polyethylene releases mostly water vapor at melt. If you take it higher it burns like wax unless the flame gets large and the temperature increases a lot. It will support a slow flame, large fast flame if mixed with wick materials like sticks and wood.
Member is Online
Post by jamesp on Dec 30, 2017 15:38:33 GMT -5
I would put it in a prominent place as a reminder what not to do. I have had a spent shotgun shell on my desk for exactly that same reason. Smile every time I see it. Long story... cost me a couple hundred bucks, but a good lesson learned. was it heated by the stove ?
Member is Online
Post by jamesp on Dec 30, 2017 15:42:07 GMT -5
The 100k machines just bring the faced pipe to the heater plate, not keep a steady pressure on it. The pressure is maintained during the fusion process. It appears to me that you had hired me to do that one. I tend to agree with Walt, except any method you have at your disposal would work. Personally, considering its a free scrap, I would put it in a prominent place as a reminder what not to do. Surprised at how neatly it melted under it's own weight. Even the blue print on those fat melt beads is still intact. Make you wonder if you could cast a slab of it.
Member is Online
Post by jamesp on Dec 30, 2017 15:43:04 GMT -5
Just recut it on a wood lathe Walt Guessing that the melted area is just as machinable as the vigin pipe Walt.
Post by HankRocks on Dec 30, 2017 16:36:04 GMT -5
Let's see... forgot to turn the burner off, ok let's say you didn't catch it in time, and the HDPE starts spilling out of the pan and into the fire. Your kitchen laboratory days could have come to a premature end!!
Post by captbob on Dec 30, 2017 16:42:04 GMT -5
I just wanna know if he got Denise a new frying pan yet.
Member is Online
Post by jamesp on Dec 30, 2017 17:16:09 GMT -5
captbob HankRocksI did buy her a new fry pan. And it is amazing. Eggs and cheese DO NOT stick to it. Not sure about plastic. When she's not at home perhaps ? I do suggest this pan. But it will scratch easy so use wood or plastic spatula. Cooked cheese eggs in it twice and used zero butter/oil. They slid off the pan. Must say they were delicious w/out the greasy crap. No idea of longevity.
spiritstone
Member since August 2014
Post by spiritstone on Dec 30, 2017 18:36:48 GMT -5
captbob HankRocks I did buy her a new fry pan. And it is amazing. Eggs and cheese DO NOT stick to it. Not sure about plastic. When she's not at home perhaps ? I do suggest this pan. But it will scratch easy so use wood or plastic spatula. Cooked cheese eggs in it twice and used zero butter/oil. They slid off the pan. Must say they were delicious w/out the greasy crap. No idea of longevity. Haha! have that set and used it today to cook eggs. The buggers just kept sliding away when I wanted to flip them over with a spatula.
Post by MsAli on Dec 30, 2017 18:42:36 GMT -5
captbob HankRocks I did buy her a new fry pan. And it is amazing. Eggs and cheese DO NOT stick to it. Not sure about plastic. When she's not at home perhaps ? I do suggest this pan. But it will scratch easy so use wood or plastic spatula. Cooked cheese eggs in it twice and used zero butter/oil. They slid off the pan. Must say they were delicious w/out the greasy crap. No idea of longevity. I was gonna buy one today. So it' not scratch resistant as it claims? *always have a replacement item available in case of experiment failure and fire extinguisher nearby
Post by captbob on Dec 30, 2017 18:43:53 GMT -5
Shoulda held them in place with somma that Flex Seal tape!
spiritstone
Post by spiritstone on Dec 30, 2017 18:53:12 GMT -5
Shoulda held them in place with somma that Flex Seal tape! Even better, Sugru.
Member is Online
Post by jamesp on Dec 30, 2017 19:27:54 GMT -5
captbob HankRocks I did buy her a new fry pan. And it is amazing. Eggs and cheese DO NOT stick to it. Not sure about plastic. When she's not at home perhaps ? I do suggest this pan. But it will scratch easy so use wood or plastic spatula. Cooked cheese eggs in it twice and used zero butter/oil. They slid off the pan. Must say they were delicious w/out the greasy crap. No idea of longevity. I was gonna buy one today. So it' not scratch resistant as it claims? *always have a replacement item available in case of experiment failure and fire extinguisher nearby Did burgers in it tonight. Cooked on Worcestershire was a bit stickier than anything else so far. Still not bad. It scratches easily though. Not sure why they claim it would take blender blades. Not. Great idea the Fire extinguisher. Wondering if the insurance would renew everything in case things go south, hmmm.
Member is Online
Post by jamesp on Dec 30, 2017 19:29:28 GMT -5
Shoulda held them in place with somma that Flex Seal tape! Even better, Sugru. Dang spirit, that stuff looks mighty handy. Never seen it. Looks to be about $.80/gram.
spiritstone
Post by spiritstone on Dec 31, 2017 11:13:27 GMT -5
Dang spirit, that stuff looks mighty handy. Never seen it. Looks to be about $.80/gram. I just caught site of it last month watching 2017 product hacks. It looks to be very versatile, have to look deeper into the product to see what it can handle before failure.
