marmmot2001
Member since December 2017
Post by marmmot2001 on Jan 1, 2018 2:40:39 GMT -5
Post by youp50 on Jan 1, 2018 4:13:41 GMT -5
The images are not opening for me.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Jan 1, 2018 8:48:35 GMT -5
I have a question . . . What do you have to offer ?
Post by captbob on Jan 1, 2018 11:32:59 GMT -5
Will the wall get built this year?
marmmot2001
Post by marmmot2001 on Jan 1, 2018 19:37:19 GMT -5
Fixed. See: www.flickr.com/photos/155346383@N06/ I am curious to see if any one has tried anything similar. I am also working on a vibralap and updating the one featured in the video with a gear reducer rather than chain drive.
Post by Jugglerguy on Jan 1, 2018 19:45:01 GMT -5
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on Jan 1, 2018 19:52:51 GMT -5
Yeah . . . I was trying to see how to get the rocks out ?
marmmot2001
Post by marmmot2001 on Jan 1, 2018 23:32:37 GMT -5
The black drum is a 18 water heater with 3/8 steel flanges welded on to it. There is a matching cap that bolts on to the flange (not pictured). Its lined with a stable mat. Before I built it I used an 80 quart aluminum stock pot lined with rubber floor mats. The green ones are schedule 40 PVC pipe a 14 foot 12 inch diameter length was about $120. I had a local steel place cut the caps which are supported by the center rod. It works really well. Even running it without a lining the barrels showed no wear after 8 weeks of operation. I'll post some more photos of the drums when I get a chance. I think the PVC design would work well for a scaled down 4,6,8,10 version since all of the stuff to make it is cheap or available on eBay for very little.
