Luminin
Member since August 2017
Post by Luminin on Jan 1, 2018 13:38:02 GMT -5
So, I've ran my first batch for a week in Cerium Oxide and wow the edges look fantastic! Perfect shine! But the rocks' faces...hardly polished at all. So, I added them back to the old slurry, removed some of the plastic pellets and added quite a bit more cerium oxide. Figure I'll give them another week and then see what's what, maybe ceramic media would do the trick? Here is one of my favorites so far:
Post by MsAli on Jan 1, 2018 13:40:33 GMT -5
Looking good Cody. Further along than I am What is the rock?
Luminin
Post by Luminin on Jan 1, 2018 13:41:00 GMT -5
A piece of my flint MsAli.
Post by MsAli on Jan 1, 2018 13:49:12 GMT -5
A piece of my flint MsAli . Thats what I thought it was.....Very pretty. manofglass sent me some, I'll get it started one of these days
Post by manofglass on Jan 1, 2018 13:58:44 GMT -5
Looks good Cody
Walt
Post by Drummond Island Rocks on Jan 1, 2018 15:48:43 GMT -5
The normal answer for that problem is more smalls. In the vibe tumbler I run a minimum of 50 percent ceramic media in batches with flats. In a rotary with plastic beads that may not be the answer.
tkvancil
Member since September 2011
Post by tkvancil on Jan 1, 2018 16:09:30 GMT -5
I never had any luck with cerium in the rotary. Aluminum oxides did better for me. I also did not like plastic pellets much. Used ceramic media and thought I got better results. For cushion I would fill the barrel to about 85% full rocks and ceramic (ceramic roughly 30%). Also would tumble in polish a minimum of 3 weeks.
vwfence
Post by vwfence on Jan 8, 2018 10:51:52 GMT -5
Is that flint natural or heat treated
Post by Sabre52 on Jan 8, 2018 11:00:05 GMT -5
Yep. what Chuck said, more smalls means more surface to surface contact. I also agree, AO or Tin Oxide as polish are better than cerium in my book. Cerium comes in various grades though and I do like optical grade cerium on pads when polishing cabs...Mel
Luminin
Post by Luminin on Jan 8, 2018 11:11:24 GMT -5
Is that flint natural or heat treated Natural, though I'm thinking about heat treating some next time.
Luminin
Post by Luminin on Jan 8, 2018 11:15:33 GMT -5
I'll order some ceramic media then. I didn't have time to open them up this weekend, so they'll be rolling for another week as is.
As to more smalls, most of what I'm running is around a half inch or less in diameter, I'd say at least 50% by weight. I'll give the cerium some more opportunities before I give up on it, at least work through what little I have.
I really think the ceramic is going to do the trick though.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Jan 8, 2018 11:35:02 GMT -5
I was having trouble in my 6-pound barrels getting a polish using some polish that came in a Grit Kit from Kingsley North, thinking it was some unknown AO. Got 2 pounds of Cerium Oxide also from Kingsley, the pink stuff. Got great results with just a couple of teaspoons in the barrel. I have reused it with small recharges up to 4 times and it still works very well. Barrels are 80% full with 50% Plastic Beads. www.kingsleynorth.com/skshop/product.php?id=46509&catID=189
Post by spiceman on Jan 8, 2018 15:49:34 GMT -5
The flint looks like it has some blue in it, or blueish gray. Nice flint. So that's a piece you found or bought? I bought some with sky blue in it It was expensive but cool looking.
I would like to see green, someone had some once But it was sold in minutes.
Luminin
Post by Luminin on Jan 9, 2018 22:33:50 GMT -5
The flint looks like it has some blue in it, or blueish gray. Nice flint. So that's a piece you found or bought? I bought some with sky blue in it It was expensive but cool looking. I would like to see green, someone had some once But it was sold in minutes. I found it. Roy Miller has the green flint. Private quarry, but I'm pretty sure he heat treats it to get the rich green color.
Luminin
Post by Luminin on Jan 9, 2018 22:35:18 GMT -5
Had to go back and look, the blueish looking streaks are actually solid quartz druzy. Opaque.
Post by jamesp on Jan 9, 2018 23:19:34 GMT -5
Go with aluminum oxide. Must be the cerium. Glass people use cerium. Better for softer material.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on Jan 16, 2018 18:48:11 GMT -5
