flminer56
Im a certified us faceters guild novice gem cutter as of 4/20
Member since September 2017
Post by flminer56 on Jan 23, 2018 18:55:23 GMT -5
This last saturday I attended a gem and mineral show and bought a slab of mariposite. At the time I didnt think to ask the seller if he knew what polish to use. I cant find anything on the web about it. does any of you know or cut this material? thanks
Post by rockjunquie on Jan 23, 2018 19:37:54 GMT -5
This last saturday I attended a gem and mineral show and bought a slab of mariposite. At the time I didnt think to ask the seller if he knew what polish to use. I cant find anything on the web about it. does any of you know or cut this material? thanks Diamond wheels has worked fine for me.
goatgrinder
Make mine a man cave
Member since January 2017
Post by goatgrinder on Jan 23, 2018 19:39:41 GMT -5
Welcome to the RTH home. Would you send us a picture of your newly acquired slab please? It would in the words of Dr. Phil "help us to help you".
Post by Deleted on Jan 23, 2018 22:14:55 GMT -5
Much of it is mixed hardnesses, so treat it like other mixed hardness stones to avoid undercutting. Tends to be soft, so light pressure and you can skip the coarser wheels once you get to the doming stage. I agree with diamond wheels and polish on hard leather. You can sometimes bring up the shine a bit with a final buff with ZAM. Makes very pretty gems.
flminer56
Post by flminer56 on Jan 24, 2018 17:12:47 GMT -5
thanks, ive got a piece dopped and ready to go , maybe tomorrow I can find time to cut it. I haven't had much luck posting pics here. ill try again. my pic file is always too large .
Post by Sabre52 on Jan 26, 2018 12:19:48 GMT -5
Tough one to polish to a really nice finish. I use optical grade cerium oxide on a leather pad with just enough moisture to create a good drag against the wheel. This is one you have to be careful not to overheat too as it's kind of a dolomite type mix and can fracture if it gets too hot on the pad....Mel
