RF but
Feb 21, 2018 23:27:32 GMT -5
Post by spiceman on Feb 21, 2018 23:27:32 GMT -5
I sketched a picture using pencils, Soft to hard lead. I framed it and put it up on the wall. After a couple days the drawing started to disappear and the only part remaining was the places that was drawn using the harder lead. So, I took the picture down after 2days on the floor, the drawing started to reappear. could RF cause that to happen? It sounds crazy but why did that happen?
Post by Pat on Feb 22, 2018 0:02:13 GMT -5
RF. Could not do that.
Might have been the angle of vision.
RF but
Feb 22, 2018 0:39:06 GMT -5
Post by spiceman on Feb 22, 2018 0:39:06 GMT -5
Well, it wasn't the angle of vision, I don't think because one of the people I showed put it under a light a many angles and he said, I'm not sure. The killer is out of all the people I ask, 1/2 said RF and the others said I don't know. This site has lots of smart people and I figured some might know.
Thank you
RF but
Feb 22, 2018 0:41:29 GMT -5
Post by Pat on Feb 22, 2018 0:41:29 GMT -5
Can you post the picture?
Post by amygdule on Feb 22, 2018 12:25:57 GMT -5
Maybe it's the RH affecting the paper.
Post by Rockoonz on Feb 22, 2018 13:51:54 GMT -5
The hardness of graphite is determined by the addition of clay. Less clay = softer / softer = darker lines. Probably irrelevant to your mystery but maybe the info will help someone more knowledgeable concerning photo-reactivity. Or whatever it is.
unclesoska
Member since February 2011
Post by unclesoska on Feb 22, 2018 19:09:43 GMT -5
Dumb question- What is RF? May have lotsa smart folk here, but I'm not acquainted w/ the mind readers of the group.
RF but
Feb 22, 2018 19:53:11 GMT -5
Post by spiceman on Feb 22, 2018 19:53:11 GMT -5
Dumb question- What is RF? May have lotsa smart folk here, but I'm not acquainted w/ the mind readers of the group. Sorry, but no wuestion is dumb. RF- radio frequency
RF but
Feb 22, 2018 19:55:31 GMT -5
Post by spiceman on Feb 22, 2018 19:55:31 GMT -5
Good answer Thinking out side the box.
RF but
Feb 22, 2018 20:00:14 GMT -5
Post by spiceman on Feb 22, 2018 20:00:14 GMT -5
The big reason I want to know, if it is RF why does it show in that area? Also, can RF be bad for your health? Some people know why i am interested In the answer.
Post by Pat on Feb 22, 2018 22:14:52 GMT -5
If RF is at too high a level, it would be bad for your health.
Post by mohs on Feb 23, 2018 9:10:26 GMT -5
u need to try and reduplicate the situation under controlled conditions not sure how to do that more theoretician than a practitioner moslty
AzRockGeek
Member since September 2016
Post by AzRockGeek on Feb 23, 2018 9:51:08 GMT -5
Sounds like more of a humidity issue to me. Was near an air vent?
Post by rockjunquie on Feb 23, 2018 10:43:37 GMT -5
I can almost guarantee you that it was staic electricity that lifted the softer lead. We were taught in art class that that could happen and that is why we used a spray fixative over charcoal- especially if it were to be under glass, which sets up a static field. Why I don't know, but it happens. Have you ever seen a charcoal with dust on the inside of the glass? I have. Its where the charcoal or lead was lifted.
AzRockGeek
Post by AzRockGeek on Feb 23, 2018 10:48:11 GMT -5
I asked a RF Guru and my work if the RF could possibly have any effect on a drawing, he said ONLY if the drawing media is ferrite based. RF would not have any effect on graphite.
RF but
Feb 24, 2018 23:42:40 GMT -5
Post by spiceman on Feb 24, 2018 23:42:40 GMT -5
I asked a RF Guru and my work if the RF could possibly have any effect on a drawing, he said ONLY if the drawing media is ferrite based. RF would not have any effect on graphite. Thanks, that is a good answer. but now I want to know what happened. I need to try and repeat it and take pictures of the drawing before and after. I moved the hanger from that location but I now here it should be.
RF but
Feb 24, 2018 23:46:04 GMT -5
Post by spiceman on Feb 24, 2018 23:46:04 GMT -5
Sounds like more of a humidity issue to me. Was near an air vent? The humidity is very low in the winter time and we were going thru a cold spell.
minerken
Member since August 2013
Post by minerken on Feb 24, 2018 23:57:48 GMT -5
low humidity and cold that would reinforce @rockjunquies 's static electricity description.
RF but
Feb 26, 2018 2:10:51 GMT -5
Post by spiceman on Feb 26, 2018 2:10:51 GMT -5
Yes, it does. I need to look what's on the other side of the wall. The place is old and the walls are solid plaster, no drywall.
RF but
Feb 26, 2018 2:22:35 GMT -5
Post by spiceman on Feb 26, 2018 2:22:35 GMT -5
Ok, I was moving around pictures in that area and noticed a dusting of dark spider webs. That could be the pencil lead lifting off. But, and there is always a BUT. The graphite returned to the check areas after I removed the drawing from the wall. A couple round areas about as big as a quarter are thin or void of graphite. It's getting crazier.
