Mark K
Member since April 2012
Post by Mark K on Feb 25, 2018 21:37:31 GMT -5
This dude at Burro Creek had this tool which was like the of offspring from a slide hammer that mated with a jack hammer.
It split the rock like it was nothing.
I can't find them online except specialty use ones such as for tires which is not heavy enough.
Can anyone help?
Post by pauls on Feb 26, 2018 2:32:26 GMT -5
I have never seen a factory built one, all homemade. Do a sketch and take it to a local engineering shop, it should be easy to fabricate.
Mark K
Post by Mark K on Feb 26, 2018 10:34:02 GMT -5
This one was factory. And very well made.
Post by catmandewe on Feb 26, 2018 11:16:07 GMT -5
Mark K
Post by Mark K on Feb 26, 2018 19:27:10 GMT -5
Nice
Hey Tony, what do you have for used slab saws?
Post by Fossilman on Feb 27, 2018 10:37:28 GMT -5
Dang, I used those a time or two.....I bet they would be great on rocks...LOL
rockdunker
Member since July 2017
Post by rockdunker on Feb 27, 2018 11:24:35 GMT -5
I needed one recently, found an agate boulder the size of a Volkswagen beetle and just wanted the corner piece. 30 minutes later and a few near misses I had that thing. Probably would have been easier with that slide hammer.
Post by woodman on Feb 27, 2018 11:30:27 GMT -5
I had a home made one that I tried to use. kind of worked but not any better than a good point and a drilling hammer. Hammer and point a lot easier to carry in a pack than the heavy slide hammer.
Hammer on!
NRG
Member since February 2018
Post by NRG on Feb 27, 2018 12:24:08 GMT -5
Post by catmandewe on Mar 1, 2018 11:09:55 GMT -5
What size are you needing Mark?
Tony
Mark K
Post by Mark K on Mar 1, 2018 13:47:32 GMT -5
Something 16 or up
Mark K
Post by Mark K on Mar 1, 2018 13:48:13 GMT -5
Im not going to fix my 20. Too many hoops to jump through.
vwfence
Post by vwfence on Mar 5, 2018 9:41:09 GMT -5
The tool you are looking for is made in Kingman Az and comes in 3 sizes . I have a message into a person who was selling them to get some information for you
Post by catmandewe on Mar 5, 2018 11:47:28 GMT -5
Im not going to fix my 20. Too many hoops to jump through. Bring it to Q next year, I need a new project. Right now I have a 16" Royal, good saw, has a couple of quirks but runs and cuts good. Tony
Mark K
Post by Mark K on Mar 5, 2018 17:26:02 GMT -5
OK, you have my attention
NRG
Post by NRG on Mar 6, 2018 0:12:56 GMT -5
Regarding hand powered jackhammer.
Too easy to build for $100.
Buy the hex chisel of your choice, then a hex "driver" to match. Weld that onto a length of steel bar.
Now make a tubular "hammer". Buy heavy walled steel tube to match the steel bar above (just fits inside).
Weld a 4" piece of steel bar from above in one end of the heavy tube. Weld on ear shapped handles.
Slide this piece over the first and start hammering.
