Post by mohs on Mar 7, 2018 16:10:42 GMT -5
Alright lapidary pals Explain this trick to me Neighbor owns it Doesn’t know where it came from To me --it seems to be --- natural agate Brazilian ? Its highly polished inside the concave & outside on the convex The girdle thickness is tits!~ (as in even across the whole form ) How was it cut? How was it polished! Thanks all! Ed
Mark K
Member since April 2012
Post by Mark K on Mar 7, 2018 16:31:53 GMT -5
I don't know, but I found the part that is inside of her agate panties in CA.
NRG
Member since February 2018
Post by NRG on Mar 7, 2018 16:35:17 GMT -5
Post by mohs on Mar 7, 2018 16:46:57 GMT -5
very cool NRG ! telescopic lens grinders rock !~ ya know I have lot in common w/Spinoza that sharp mind of the 17th century poor boy in his room grinding lenses for a living well I'm poor and grind but the mind still bit rough m stly
Post by Jugglerguy on Mar 7, 2018 16:54:05 GMT -5
It looks like a giant contact lens. Don’t drop it, you’ll never find it.
Post by mohs on Mar 7, 2018 16:59:03 GMT -5
Could of name it cyclops lens but i had mermaids on my mind m slty cool
zarguy
Member since December 2005
Post by zarguy on Mar 7, 2018 17:19:22 GMT -5
I've seen stackable agate bowls like these. I think they're made on a lathe. A cutting tool can be made to cut a curve without wasting all the material between bowls. I could be wrong, but that's how I'd do it. Lynn
Post by MsAli on Mar 7, 2018 17:20:04 GMT -5
Could of name cyclops lens but i have mermaids on my mind m slty Part of her magic girdle? As Aphrodite did not wear a bra
gemfeller
Member since June 2011
Member is Online
Post by gemfeller on Mar 7, 2018 17:27:09 GMT -5
Post by mohs on Mar 7, 2018 17:32:56 GMT -5
yep ali! I've noticed that in all the classical paintings of Aphrodite and just to be fair and don't get me started on the quest for the lost wall size marble mosaic of Beauty & the Beast residing in some Venice museum...
Post by mohs on Mar 7, 2018 17:35:40 GMT -5
Thanks Rick! I was thinking you'd probably have some insight I'll check those sites out hope it going well Ed
Post by mohs on Mar 7, 2018 18:09:14 GMT -5
Post by MsAli on Mar 7, 2018 18:13:48 GMT -5
That is really pretty
Post by mohs on Mar 7, 2018 18:17:27 GMT -5
yes it is! an perfectly formed it as me completely flummox Ed mohs
Post by fernwood on Mar 7, 2018 18:18:51 GMT -5
That is very cool. Agree with the bowl response. Does it look like the center crystals fell out over time, or was it made like this? A friend told me about some musical meditation bowls she was given. One set was the traditional, white cylinder type. The other set she said looked like "woks made out of agates". Your photos certainly show an agate wok.
Post by mohs on Mar 7, 2018 18:25:11 GMT -5
O I'm pretty sure mrsfern that the center what the proper name?
is natural and intact
in example --I believe it was ground that way for effect the hole was naturally there
Post by mohs on Mar 7, 2018 18:28:20 GMT -5
I just hung it from wire and tap it it rings like rock
Post by pauls on Mar 7, 2018 23:30:49 GMT -5
The cutter for these is a saw blade that is dish shaped, (imagine say a half soccer ball on a shaft) several blades are stacked together on the shaft with a spacer between each equivalent to the thickness you want your little Agate bowl. The stone is held in a lathe type machine so that it slowly rotates, the cutter also spins like a diamond saw, but it also needs to cut in an arc as well, as the cutter cuts into the rock the axis of the shaft swivels and allows the dished blade to cut multiple dished slabs of rock.
Thats hard to describe but if you get it figured it's really simple. Much easier to describe with lots of hand waving.
There was a picture of the machine in a very ancient US lapidary magazine, probably 1970s. I did have it saved on my computer about seven computers ago, so it's long gone and I can't find the magazine either.
Post by mohs on Mar 8, 2018 11:31:05 GMT -5
One of the strange aspects is that the rim as the outer crust Of the rock That seems to preclude that it was ground aa a sphere first
Its like someone sliced a slab of agate And molded it. Like glass.
Is it possible heat and bend agate?
Post by mohs on Mar 8, 2018 15:29:43 GMT -5
mohs
