Post by Drummond Island Rocks on Mar 13, 2018 9:31:15 GMT -5
This is part two to my obsidian post last week. As most of you know obsidian needs a lot of filler in the final stages so the batches get split into two after 120/220. There are a few that developed flaws. That is normal so I left them in the picture. Those few will get pulled and ran again in the future Chuck
Post by MsAli on Mar 13, 2018 9:32:45 GMT -5
Beautiful!!!
Post by hummingbirdstones on Mar 13, 2018 9:33:30 GMT -5
Those are gorgeous!
Post by Fossilman on Mar 13, 2018 10:11:17 GMT -5
Holy Molly those are NICE!
Win
Member since June 2017
Post by Win on Mar 13, 2018 10:27:11 GMT -5
I love Obsidian, have had good results, still trying for better. I did really increase my ceramics and that helped, also running longer in polish.
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Mar 13, 2018 10:31:26 GMT -5
Love that shine.
stubshaft
Member since March 2018
Post by stubshaft on Mar 13, 2018 15:35:55 GMT -5
Awesome!
Post by fernwood on Mar 13, 2018 18:01:22 GMT -5
Nice shine for sure.
Post by Drummond Island Rocks on Mar 13, 2018 18:27:57 GMT -5
I love Obsidian, have had good results, still trying for better. I did really increase my ceramics and that helped, also running longer in polish. Thanks Are you using rotary or vibe for polish? These spent 48 hours in the polish stage in the lot-o Chuck
Win
Post by Win on Mar 14, 2018 11:10:01 GMT -5
I love Obsidian, have had good results, still trying for better. I did really increase my ceramics and that helped, also running longer in polish. Thanks Are you using rotary or vibe for polish? These spent 48 hours in the polish stage in the lot-o Chuck Lot O, 72 hours with CO. Prepping in rotary, QT66, running 7 days, changing grit and running 4 days. Running the rotary very full with ceramics, really helped keeping down the bruising/chipping.
Post by Drummond Island Rocks on Mar 14, 2018 11:15:27 GMT -5
WinFor what is worth these were tumbled in stage (46/70) one at normal fill level in a mixed rock batch containing mostly agates and jaspers. No fillers no smalls. Stage two in the loto 120/220 SC for 48 hours. Stage three loto 500 AO for 96 hours. Stage four was AO polish from the rockshed for 48 hours. That's it in a nutshell. Not even a burnish stage. All of my obsidian and apache tears go through stage one in mixed rock batches with no specail treatment. I set them aside at stage one clean outs to run in dedicated batches when they hit the loto though. Plenty of different recipes out there but this one has never failed me. Chuck
ChicagoDave
Member since June 2016
Post by ChicagoDave on Mar 14, 2018 12:31:04 GMT -5
Win For what is worth these were tumbled in stage (46/70) one at normal fill level in a mixed rock batch containing mostly agates and jaspers. No fillers no smalls. Stage two in the loto 120/220 SC for 48 hours. Stage three loto 500 AO for 96 hours. Stage four was AO polish from the rockshed for 48 hours. That's it in a nutshell. Not even a burnish stage. All of my obsidian and apache tears go through stage one in mixed rock batches with no specail treatment. I set them aside at stage one clean outs to run in dedicated batches when they hit the loto though. Plenty of different recipes out there but this one has never failed me. Chuck This is how I always did my obsidian and apache tears also (well close enough). The only difference was I only did 48 hours in 500AO and added 48 hours in 1000AO. There were always some that developed a chip or scratch. I grabbed them after final polish and threw them back into general population.
Win
Post by Win on Mar 14, 2018 14:39:01 GMT -5
I didn't have good results with the RS AO Polish, switching to the CO really helped. I run 120/220 48 hrs, AO500 96 hours, CO 72 hrs and then burnish with 2 tpsp Borax and some Ivory Soap shavings. I'll adjust a bit and see what happens, should run some next week.
Win
Post by Drummond Island Rocks on Mar 14, 2018 14:51:37 GMT -5
I didn't have good results with the RS AO Polish, switching to the CO really helped. I run 120/220 48 hrs, AO500 96 hours, CO 72 hrs and then burnish with 2 tpsp Borax and some Ivory Soap shavings. I'll adjust a bit and see what happens, should run some next week. Win Wow, that's the first time I have heard of any issues using RS AO polish. When I first started I was messing around with cerium and tin oxide but for at least the last five years I have used AO polish 100% of the time. Hopefully nothing has changed with what is being sold now. I have mentioned before that I originally learned how to run obsidian from the tutorial tntmom made available. It is harder to find now but I have a copy if you would like it. Chuck
Win
Post by Win on Mar 14, 2018 15:00:27 GMT -5
Thanks, I have that copy and that's pretty much what I follow. With the AO, I just couldn't get a glassy polish, switched to CO and it worked. I use AO for all my other runs, just finished a mixed batch, mostly crazy lace, came out great. Here's my first batch of Obsidian.
Post by tntmom on Mar 14, 2018 15:19:47 GMT -5
I didn't have good results with the RS AO Polish, switching to the CO really helped. I run 120/220 48 hrs, AO500 96 hours, CO 72 hrs and then burnish with 2 tpsp Borax and some Ivory Soap shavings. I'll adjust a bit and see what happens, should run some next week. Win Wow, that's the first time I have heard of any issues using RS AO polish. When I first started I was messing around with cerium and tin oxide but for at least the last five years I have used AO polish 100% of the time. Hopefully nothing has changed with what is being sold now. I have mentioned before that I originally learned how to run obsidian from the tutorial tntmom made available. It is harder to find now but I have a copy if you would like it. Chuck Tommy uploaded the tutorial here on the forum www.rocktumblinghobby.com/files/ObsidianTumblingRecipe.pdf
