Post by Jugglerguy on Mar 22, 2018 19:35:50 GMT -5
I enjoy cutting out shaped and tumbling them. I mostly do crosses, but I have done shamrocks and Michigan shapes and a couple others. I thought it was time to try some new ones. Here's what I came up with. I don't like the turtle much at all, the duck is ok, I kind of like the bear, but I think I should do it in a black rock. These are all Michigan rocks that I've picked up, but I haven't tumbled a lot of black Michigan rocks, so I'm not quite sure what to pick up that will look interesting and tumble well. I really like the heart, but that one took much more time since I domed it on both sides. I'll be doing more of those. The red cross came from the same slab as the heart. I found that here in Alpena. I originally thought it was jasper, but now I think it looks more like some sort of jaspelite, at least I think that might be iron in there. The cross side of the slab had much more of the silver color than the heart side of the slab. The rest of the batch was scraps from making lots of crosses.
Post by MsAli on Mar 22, 2018 19:39:29 GMT -5
I like the bear and the duck a lot You tumble in a vibe?
Post by vegasjames on Mar 22, 2018 19:44:03 GMT -5
Very nice, really like the duck. Looks like a lot of work to make all the cuts. Are you doing this with a hand coping saw or a diamond wire band saw?
Post by Jugglerguy on Mar 22, 2018 19:48:07 GMT -5
I like the bear and the duck a lot You tumble in a vibe? Yep, I use a Lot-O.
Post by Jugglerguy on Mar 22, 2018 19:50:10 GMT -5
Very nice, really like the duck. Looks like a lot of work to make all the cuts. Are you doing this with a hand coping saw or a diamond wire band saw? Neither. I use a trim saw. It doesn't take long at all. I was worried the duck would break, but it held up well.
Post by Fossilman on Mar 22, 2018 21:12:48 GMT -5
Wow,how cool are those!!!! Liking the cutting table to.....
Post by rockpickerforever on Mar 23, 2018 7:37:55 GMT -5
Looks like a lot of work! Great job cutting them out, and they tumbled up nicely.
Fridge magnets? Or do you plan to glue some bails on them? I can see them worn around the neck on a cord by both males and females.
Thanks for sharing.
Post by Garage Rocker on Mar 23, 2018 8:31:27 GMT -5
Very cool, Rob. That material looks good in a heart. The duck looks labor intensive, but came out great.
Post by fernwood on Mar 23, 2018 8:50:10 GMT -5
Those are great. Love the animals. I use drilled animal festish beads a lot. Why not try the side view of a fish? About the shape of a Walleye. I had some like than many years ago and can no longer find them. I love the colors of the bear.
tkvancil
Member since September 2011
Post by tkvancil on Mar 23, 2018 10:00:16 GMT -5
Admirable work Rob. Gotta go against you on the turtle however I like him as well as the rest.
Post by Jugglerguy on Mar 23, 2018 10:19:33 GMT -5
Those are great. Love the animals. I use drilled animal festish beads a lot. Why not try the side view of a fish? About the shape of a Walleye. I had some like than many years ago and can no longer find them. I love the colors of the bear. I have a fish shape drawn out, I just haven't done it yet.
Post by Jugglerguy on Mar 23, 2018 10:24:54 GMT -5
Looks like a lot of work! Great job cutting them out, and they tumbled up nicely. Fridge magnets? Or do you plan to glue some bails on them? I can see them worn around the neck on a cord by both males and females. Thanks for sharing. Usually I do fridge magnets. The heart is drilled for an eye.
Post by hummingbirdstones on Mar 23, 2018 10:31:23 GMT -5
Those are amazing! Thanks for the video showing how you do it. I never even thought about making a cutting jig like that to aid in sawing out shapes. Thanks for sharing.
Post by Jugglerguy on Mar 23, 2018 15:27:54 GMT -5
Those are amazing! Thanks for the video showing how you do it. I never even thought about making a cutting jig like that to aid in sawing out shapes. Thanks for sharing. The jig is so that the blade and the table (ramp) make a 90 degree angle. Without that, the bottom of the rock would get cut more than the top because the blade is wider closer to the table.
Post by hummingbirdstones on Mar 23, 2018 15:38:33 GMT -5
The jig is so that the blade and the table (ramp) make a 90 degree angle. Without that, the bottom of the rock would get cut more than the top because the blade is wider closer to the table. It's such a simple solution to that problem. I wrecked a nice piece of Hell's Canyon because of that a few years ago. Didn't take into account that the blade was wider at the bottom. Doh! Guess what DH is doing this weekend?
Post by Jugglerguy on Mar 23, 2018 15:53:08 GMT -5
The jig is so that the blade and the table (ramp) make a 90 degree angle. Without that, the bottom of the rock would get cut more than the top because the blade is wider closer to the table. It's such a simple solution to that problem. I wrecked a nice piece of Hell's Canyon because of that a few years ago. Didn't take into account that the blade was wider at the bottom. Doh! Guess what DH is doing this weekend? Actually, I didn’t use the saw in the video to make the shapes in this post. I have a new (used) saw that has the arbor at the level of the table so the blade is already perpendicular to the table. No ramp required.
rockcat11
Member since August 2017
Post by rockcat11 on Mar 24, 2018 16:24:43 GMT -5
those are amazing. Am I correct in assuming that you can only do something like that in a vibe?
Post by Jugglerguy on Mar 24, 2018 17:25:31 GMT -5
those are amazing. Am I correct in assuming that you can only do something like that in a vibe? Yes, vibes don’t change the shape too much, they just round off the sharp corners a little.
melf77
Member since July 2017
Post by melf77 on Mar 26, 2018 9:37:15 GMT -5
Thanks for posting. This is exactly what I wanted to try to start doing this summer.
Post by Jugglerguy on Mar 26, 2018 10:19:45 GMT -5
Thanks for posting. This is exactly what I wanted to try to start doing this summer. Let me know if you need any help.
