Post by docktondiamonds on Apr 9, 2018 23:30:40 GMT -5
hey everyone I'm fairly new to tumbling but have a few barrels under my belt (with varying degrees of success). I'll spend a little time settling in then bombard y'all with "what do think this is....?", "how do I go about doing this....?" type questions. Glenn
Post by aDave on Apr 10, 2018 0:08:50 GMT -5
Welcome to the forum from Southern CA.
Ask away. Lots of knowledgeable folks here in many aspects of the lapidary world.
Post by MsAli on Apr 10, 2018 0:20:18 GMT -5
Welcome Glenn from Fresno California
Post by gmitch067 on Apr 10, 2018 8:08:33 GMT -5
Welcome Glenn to the Forum from Northern California! If you want to create a thread (statement or question) open the FORUM menu at the top of the page. For rock tumbling questions: Under the section LAPIDARY DISCUSSION TOPICS, select ROCK TUMBLING. At the top of the section (just above the page numbers and the SELECT / ACTION / SEARCH line) is a line that has ROCK TUMBLING on the left and CREATE THREAD on the right. Select CREATE THREAD. Type in a SUBJECT that abbreviates your need (key words help to focus other's attention) Type in your question (or statement) in the text box below. For rock identification: Use the same procedure... FORUM ADDITIONAL ROCK RELATED TOPICS ROCK IDENTIFICATION (Note: It helps me allot to create my questions using a text editor first - like Microsoft Word - and then to cut and paste the question into that text box. Once you have pasted the question, go through your text and add correct spacing and highlights. If while doing this you loose all your editing... it happens to me now and again... you can easily go back to your text editor and do another copy and paste.) I hope this helps you. Glenn (catchy name... Sorry... not Irish.
Post by hummingbirdstones on Apr 10, 2018 9:02:03 GMT -5
Welcome from Northern Arizona!
Post by aDave on Apr 10, 2018 9:26:15 GMT -5
(Note: It helps me allot to create my questions using a text editor first - like Microsoft Word - and then to cut and paste the question into that text box. Once you have pasted the question, go through your text and add correct spacing and highlights. If while doing this you loose all your editing... it happens to me now and again... you can easily go back to your text editor and do another copy and paste.) Or, you can let the forum software save your draft for you while you're working on it. Go to My Profile>Edit Profile>Settings. There you'll see an option for "Enable Drafts." Select "yes" and then save the changes. With this enabled, the post you're working on is saved until you actually post it. It's a nice option. If you accidentally close your browser before you post, a reply box with your draft post will pop up when you return to the forum. You'll have the option of using it or discarding it.
Post by gmitch067 on Apr 10, 2018 10:48:19 GMT -5
Thanks aDave! I will do that. Glenn
rads
Making clay each day!
Member since April 2018
Post by rads on Apr 10, 2018 11:19:27 GMT -5
Welcome from Michigan. Spent most of my Naval career in the Puget Sound area. Beautiful country.
Post by vegasjames on Apr 10, 2018 15:49:26 GMT -5
Welcome Glenn from Las Vegas.
nchillbilly
Member since January 2018
Post by nchillbilly on Apr 10, 2018 16:53:44 GMT -5
Good evening and welcome to the forum from North Carolina.
Post by Noosh9057 on Apr 10, 2018 17:57:38 GMT -5
Welcome to the forum from Texas.
Roger
Post by Tommy on Apr 11, 2018 20:15:12 GMT -5
Welcome from N.CA
agrippa1307
Post by agrippa1307 on Apr 12, 2018 0:31:51 GMT -5
Welcome aboard from Olympia, Wa
Post by Fossilman on Apr 12, 2018 9:23:19 GMT -5
Howdy and welcome.. Welcome to the rainy season...LOL
Post by drocknut on Apr 12, 2018 14:03:11 GMT -5
Welcome to the forum from Arizona
Post by TheRock on Apr 19, 2018 23:59:27 GMT -5
