timloco
Member since April 2012
Post by timloco on May 7, 2018 15:44:34 GMT -5
Hi all, I have some slivers of opal that I want to try making some triplets out of. I have a clear quartz crystal I'm going to slab up for the top, but about the darkest thing I have for the back is some not very "rainbowy" rainbow obsidian. Should that work? Never done a triplet before.
Post by pauls on May 7, 2018 16:11:08 GMT -5
Yep that will do the job.
There's a woman at my club that backs her opals with black radiator putty, it works. I think its probably Sodium silicate as it sets like rock.
Not exactly my cup of tea, just putting it here as an idea.
timloco
Post by timloco on May 7, 2018 16:19:24 GMT -5
radiator putty! Yea, I guess that would work. I've used metal epoxy on other stones for the back and never really liked it even though nobody will see it when it's in a setting.
Post by bobby1 on May 8, 2018 0:43:46 GMT -5
My preference is Basanite. It is durable, inexpensive and polishes very well. Bob
Post by vegasjames on May 8, 2018 2:50:40 GMT -5
Seems like obsidian would splinter easy. I would go with a black basalt or even ilmenite.
timloco
Post by timloco on May 8, 2018 8:15:49 GMT -5
Where does one get basenite or ilmenite?
Post by vegasjames on May 8, 2018 17:22:41 GMT -5
I get ilmenite about 50 miles North of here. It is a pitch black titanium ore.
gemfeller
Member since June 2011
Post by gemfeller on May 9, 2018 1:20:34 GMT -5
Where does one get basenite or ilmenite? It's a little expensive to make a Nevada field trip for ilmenite, so if you'll PM me your address I'll send you a slab of basanite big enough for your project. Let me know the size you need. I have quite a bit of it to use for making doublets and Idaho opal triplets. It's simply fine-grained black basalt.
Post by opalpyrexia on May 9, 2018 10:51:05 GMT -5
I use black jade and add a tiny amount of Mars Black to the epoxy. Also, after having a few too many doublets with tiny, stray bubbles in the epoxy showing through the opal, I decided to do what an Australian cutter recommended. I spray a light coat of Testor's flat black model paint on the back of the opal prior to epoxying — no more visible bubbles.
