timloco
Member since April 2012
Post by timloco on May 24, 2018 15:07:09 GMT -5
Sigh... didn't turn out quite the way I wanted, some bubbles in the bottom of both and one has a fracture that I didn't notice until after I glued it. But, I didn't spend a lot on this lot of opal so it was more a learning experience than anything. The before picture, I used the two stones on the right: And here's the stones after: It really made the flash pop having that dark background!
Post by MsAli on May 24, 2018 15:08:35 GMT -5
Pretty!
Post by orrum on May 24, 2018 16:22:33 GMT -5
Hey I think that's pretty darn good!#!
Post by fernwood on May 24, 2018 16:32:03 GMT -5
Great looking opals.
Post by rockjunquie on May 24, 2018 18:54:09 GMT -5
Looks good to me. I think for your first time, they are fine.
Post by opalpyrexia on May 24, 2018 22:11:30 GMT -5
Very nice, Tim. Thanks!
timloco
Post by timloco on May 25, 2018 13:45:45 GMT -5
Thanks for the comments! Yea they're ok, I think I can make them look good in some jewelry.
zarguy
Member since December 2005
Post by zarguy on May 25, 2018 13:51:41 GMT -5
Nice. What are you using for the backing? Lynn
timloco
Post by timloco on May 25, 2018 15:07:51 GMT -5
Nice. What are you using for the backing? Lynn I'm using some basenite donated by gemfeller with a 303 epoxy that I mixed with some Mars Black pigment donated by opalpyrexia (thanks guys) Love the community here!
Post by mohs on May 25, 2018 15:35:08 GMT -5
cool cut pair project on !
gemfeller
Member since June 2011
Post by gemfeller on May 25, 2018 20:18:38 GMT -5
Good job timloco . A suggestion for preventing bubbles showing in doublets: mix the epoxy very slowly to avoid creating as many bubbles as possible, then heat it a minute or so under an incandescent light bulb to make it runnier. When the opal's in place on the basanite use a clean pencil eraser to push down on the opal to squeeze out any remaining bubbles. The eraser helps prevent slipping on the slick opal surface. Works for me.
timloco
Post by timloco on May 26, 2018 12:19:48 GMT -5
Good job timloco . A suggestion for preventing bubbles showing in doublets: mix the epoxy very slowly to avoid creating as many bubbles as possible, then heat it a minute or so under an incandescent light bulb to make it runnier. When the opal's in place on the basanite use a clean pencil eraser to push down on the opal to squeeze out any remaining bubbles. The eraser helps prevent slipping on the slick opal surface. Works for me. Great advice! I noticed it did slip a little when I pushed down on them. The next ones will be better for sure now that I made my mistakes and learned from them :-)
Post by Rockoonz on May 26, 2018 23:05:20 GMT -5
I mix my 303 slowly, never lifting the mixing stick out of it, and wave a butane torch across the epoxy to pull the bubbles out. My experience so far has been entirely with Spencer ID opal so mine are triplets with quartz caps.
