Post by toiv0 on May 30, 2018 10:10:17 GMT -5
Check your local Lowe's
Post by MsAli on May 30, 2018 10:29:33 GMT -5
Wow that's a good deal
Post by johnjsgems on Jun 11, 2018 11:52:01 GMT -5
Good price depending on what it is made for. If a tile blade if matrix is soft enough to cut rock. If an angle grinder masonry blade same thing. Can't read the details on package in photos.
Post by jamesp on Jun 16, 2018 2:55:06 GMT -5
Good price depending on what it is made for. If a tile blade if matrix is soft enough to cut rock. If an angle grinder masonry blade same thing. Can't read the details on package in photos. I use a tuck blade and it cuts and shapes mohs 7 about as fast as any diamond tool I ever used. The brand I use wears slowly and cuts a lot of rock. It uses coarse diamonds and is 7 inches. Fits on 3450 RPM tile saw. They can be spun fast which makes a big difference in cutting rate. The high speed is the game changer. And using the corner of the wheel for point contact for mass removal. The toughness of the matrix that holds the diamonds is a concern when shaping Mohs 7. I have used 2 brands of tuck wheels and would consider them hard matrix for hard materials.
Post by melhill1659 on Jun 16, 2018 6:42:48 GMT -5
Those tags are yeller Jim... sure it’s Lowe’s and not Home Depot 😂
Post by jamesp on Jun 18, 2018 10:36:10 GMT -5
Those tags are yeller Jim... sure it’s Lowe’s and not Home Depot 😂 Check out this tuck blade Mellisa. A marauder of hard Texas petrified palm. I think I showed you this beast when you were at the house.
Post by johnjsgems on Jun 18, 2018 11:40:37 GMT -5
Not to argue but hard matrix for soft materials. Allows fast, abusive cutting of tiles, etc. with long life. Softer matrix more readily exposes diamonds to rock for faster, smoother rock cutting with shorter blade life as a trade off. Cheap tile blades cut rock very slowly but ganged make terrific long lasting grinding wheels.
