Post by rmf on Jun 19, 2018 16:58:07 GMT -5
Post by Rockoonz on Jun 19, 2018 23:10:05 GMT -5
That would be the price one would expect to pay for a plug and play unit with motor and switch out here in the NW, but it may be less common in your region. they are good solid units that are reasonably easy to work on.
Post by johnjsgems on Jun 21, 2018 12:43:51 GMT -5
Yes, I sold one just like it with the silicon carbide wheels last year for $550. The original paint and like new condition is unusual though.
Post by stardiamond on Jun 21, 2018 19:44:20 GMT -5
I'd love to find one like that. Replace the wheels with diamond and a person would be able to do some serious cutting and use another machine for 600 grit up or batch the work and swap in 3 finer wheels.
Post by johnjsgems on Jun 25, 2018 10:50:07 GMT -5
Expanding drum with multiple belts works very well. Just cut multiple stones and change belt each step.
sophia13
RIP Jason Strickland, AKA sophia13
Member since March 2018
Post by sophia13 on Jun 25, 2018 19:28:00 GMT -5
Expanding drum with multiple belts works very well. Just cut multiple stones and change belt each step. JohnJSGems,
I'd like your opinion ---I've got an 8" Raytech GemMaker and thinking about converting the left drum to an 80 grit diamond wheel, the 2 middle wheels to 220 and 280 Diamonds and leaving the right Drum for 600 Belts and up. Does that sound like a good idea or should I put wheels in the middle (4 if possible where the 2 wheels are now) and one where the right drum is. Going for a 6 wheel setup like the Genie but with a much sturdier machine). How many 8"x2" wheels do you believe will fit in the middle section? Thanks for your help and advice.
