jeffc
Member since July 2018
Post by jeffc on Jul 4, 2018 12:25:01 GMT -5
Hello everyone. I am new to the board and I already have a question. I went out and bought a used Ultra-vibe 10 vibrating machine and it is of course loud and moves about. It has three small screws on the bottom that look like it should be anchored to something, but I was looking for suggestions as to what is best to anchor it to, and what surface to put the whole thing on as I assume it will vibrate around and move around. Thanks
Post by MsAli on Jul 4, 2018 12:41:33 GMT -5
Welcome from Fresno California Cant help with your question, but I know there are some amazing people here that will be able.to help you
Post by wigglinrocks on Jul 4, 2018 13:04:43 GMT -5
Welcome to the RTH . I think the three screws are to hold rubber feet on to the bottom . No need to anchor it down if loaded properly .
Post by Fossilman on Jul 4, 2018 13:43:29 GMT -5
Welcome to RTH!
Post by Pat on Jul 4, 2018 14:10:50 GMT -5
I don’t have any suggestions, but we have plenty of knowledgeable members. Welcome from California!
Post by vegasjames on Jul 4, 2018 16:31:02 GMT -5
Welcome to the forum.
Post by hummingbirdstones on Jul 4, 2018 23:13:47 GMT -5
Welcome from Northern Arizona!
Post by Jugglerguy on Jul 5, 2018 12:12:36 GMT -5
Welcome Jeff! I have a different vibratory tumbler, so I don’t have any suggestions for you.
Post by HankRocks on Jul 5, 2018 12:30:30 GMT -5
Check to see that all the bolts holding the springs(4 I think) are properly tightened. Also make sure the center bolt that the barrel slips over and is the barrel and lid tightening bolt is not loose. My UV-18 has sheared off two of these in the last couple of years. I caught one before it completely sheared off the other time not so lucky and had a large mess to clean as it was doing a burnishing(soap) run.
There should also be a wingnut and washer assembly connecting the barrel to the base and one for the lid. make sure they are both tightened firmly.
I also added a couple of layers of rubber between the barrel and the base to help dampen the noise as the old padding had worn thin. You can also use the gasket material they sell in sheets at Auto Parts stores.
Post by Rockoonz on Jul 5, 2018 18:49:43 GMT -5
The screw holes are for rubber feet. We have 2 uv10 units that live on our covered patio. As wigglinrocks said, no need to bolt down. I hope yours is the UV10 industrial version with the blue stripe on the barrel, the other is intended for dry tumbling.
mgrets
Member since February 2011
Post by mgrets on Jul 8, 2018 10:31:53 GMT -5
Welcome from Ohio!
saxplayer
Member since March 2018
Post by saxplayer on Jul 8, 2018 15:16:15 GMT -5
Welcome! You have some good advice above, please keep posting for help if needed!
jeffc
Post by jeffc on Jul 11, 2018 23:20:18 GMT -5
Check to see that all the bolts holding the springs(4 I think) are properly tightened. Also make sure the center bolt that the barrel slips over and is the barrel and lid tightening bolt is not loose. My UV-18 has sheared off two of these in the last couple of years. I caught one before it completely sheared off the other time not so lucky and had a large mess to clean as it was doing a burnishing(soap) run. There should also be a wingnut and washer assembly connecting the barrel to the base and one for the lid. make sure they are both tightened firmly. I also added a couple of layers of rubber between the barrel and the base to help dampen the noise as the old padding had worn thin. You can also use the gasket material they sell in sheets at Auto Parts stores.
jeffc
Post by jeffc on Jul 11, 2018 23:21:06 GMT -5
Thank you for your advice. I will apply it this weekend
Post by TheRock on Aug 1, 2018 3:46:54 GMT -5
Howdy jeffc to RTH Forum from Duke in SW Michigan. I have a Brand New Utra Vibe 18 tat I just put into operation and mine doesn't move a bit which totally shocked me for as much noise it makes and the boiling action inside it stays on my bench smooth as silk. I would do what Hank Suggests and if that doesn't solve the problem you should contact the mfg or who you purchased it from. What kind of bench or table is it setting on? If it is something that is not so nice you can use a couple Plastic Caps and put them so the rubber feet bumpers sit in them. You can epoxy or drive a roofing nail down through them then place tumbler feet in them two should hold it from walking off the table. Good Luck! ~Duke
