paulh
Member since July 2018
Post by paulh on Jul 6, 2018 8:27:24 GMT -5
Is it better to use grit or ball bearings to polish stones I have just got a tumbler and it came with some small bearings so I am wordering if i should still use grit or just those? any advice appreiciated. Thanks Paul
Post by Rockoonz on Jul 6, 2018 8:47:49 GMT -5
Any metal mixed with the stone in a tumbling batch will generally get ground off by the stone and pretty much indelibly deposited on the surface of the stone. In other words, don't do it!. Steel shot can come in handy for impact hardening and polishing of softer metals though, if you wire wrap or fabricate silver it may be good to hang on to your bearings. jamesp please correct me if I'm off base here.
Post by Rockoonz on Jul 6, 2018 8:51:07 GMT -5
Oh, and BTW, welcome to the forum paulh
Post by Fossilman on Jul 6, 2018 9:19:25 GMT -5
Welcome to RTH....Go with the grit!
paulh
Post by paulh on Jul 6, 2018 10:29:05 GMT -5
many thanks, guys.
Post by TheRock on Aug 1, 2018 13:21:03 GMT -5
Howdy paulh to RTH Forum from Duke in SW Michigan You will loose your bearings if you do it! stay with Grit. ~Duke
