lancemountain
Member since March 2017
Post by lancemountain on Aug 19, 2018 15:40:37 GMT -5
Hello- I have have a few issues with cracks in the later stages of polishing in LOT-O I've always used the small ceramic media. These are what I use therockshed.com/grit/Sm_Ceramic.jpgThis week I purchased mixed sized media but when they arrived the larger ones are fairly large. They are a mix of the small and this size therockshed.com/grit/Lg_Ceramic.jpgAre these too big to use? They are the size of most of the rocks I polish! Or should I be using much more smaller cermaic than I have been?
Post by gmitch067 on Aug 19, 2018 21:35:32 GMT -5
Using the larger ceramic media probably will not hurt... But if the large ones are the same size as the stones you are processing, I would use only the smaller ceramics.
If you are running a load of brittle or highly fractured stone (example - Amethyst or Iolite) I would change my ceramic ratio to 50-50 rocks to ceramics - using only small ceramics (or 0.25in polished aquarium gravel).
Post by Jugglerguy on Aug 20, 2018 8:46:13 GMT -5
I use that same mixture. I haven’t had a problem with it.
Post by Garage Rocker on Aug 20, 2018 11:39:56 GMT -5
I use that same mixture. I haven’t had a problem with it. X2
Post by victor1941 on Aug 20, 2018 21:15:43 GMT -5
I tumble in a uv-18 vibe for polishing cabs and use a 50/50 mix of small media and cabs with good results.
lancemountain
Post by lancemountain on Aug 22, 2018 0:24:48 GMT -5
ok thank you! I think I was more 30% ish with the ceramics!
