vwfence
Post by vwfence on Sept 3, 2018 9:51:36 GMT -5
HAs anyone ever used dip it or a similar rubberized plastic on the inside of cabbing machine s in the bottom and back splash
Post by Pat on Sept 3, 2018 10:25:31 GMT -5
Why would you want to?
vwfence
Post by vwfence on Sept 3, 2018 10:32:20 GMT -5
to make it totally water proof and fix any leaks in seams ext and it should never rust again
Post by woodman on Sept 3, 2018 10:33:05 GMT -5
I could see the need if the paint failed and you were getting rust in the bottom. But that said a good cleaning and repainting might be just as good as a coating.
vwfence
Post by vwfence on Sept 3, 2018 10:44:20 GMT -5
Its just a thought , and would be easier to use than 2 part paints
Post by manofglass on Sept 3, 2018 10:47:53 GMT -5
If I needed a liner I would cut it out of sheet plastic There not hard to make
Post by Rockoonz on Sept 3, 2018 13:22:18 GMT -5
I used some POR15 on an old rusty Lortone arbor once. Spendy but it worked well. I think there are some less expensive similar products out there but haven't tried them.
vwfence
Post by vwfence on Sept 4, 2018 10:59:43 GMT -5
Rockoonz , i beleive Eastwood has stuff for restoring old cars that is like por15 . I have a friend who does Rhino lining and i am thinking of trying some on one of my machines when i redo it
Post by vegasjames on Sept 4, 2018 17:33:09 GMT -5
I would either add a sacrificial zinc anode or spray the areas with a rust concerting paint. These paints have a phosphate compound that converts the rust in to a protective layer.
