Post by MsAli on Sept 5, 2018 21:08:12 GMT -5
Last weekend I went out to the middle of no where and dug for quartz crystal. It was miserable, hot, dusty, still smelled of smoke from the fire. I wasnt having fun at that time. I didnt bring back alot, did end up with 2nd degree burn and lost almost 6lbs in 8 hours.😂 It was hard work, but I'll do it again in a heartbeat, that is when it isnt so hot. So here is my question and please bear with me for maybe being ignorant about this But, what do you look for to see if there is gold in it? All around us is gold claims, so it isnt unreasonable to possibly find gold where we were I have them soaking in iron out now. They were in vinegar, but that didnt do much I looked online, but it didnt help much Thank you
gemfeller
Member since June 2011
Post by gemfeller on Sept 5, 2018 21:44:04 GMT -5
MsAli , Gold in quartz is pretty obvious in most cases. I'm sure there are types I've not seen but I've cut quite a few gold/quartz cabs over the years. This is one I cut several years ago -- that gold is pretty obvious since it's one of the very few metals that don't tarnish. Pyrite in quartz is often mistakenly thought to be gold.
Post by fantastic5 on Sept 5, 2018 21:49:36 GMT -5
You found some really pretty points Allison!
Post by MsAli on Sept 5, 2018 21:50:06 GMT -5
MsAli , Gold in quartz is pretty obvious in most cases. I'm sure there are types I've not seen but I've cut quite a few gold/quartz cabs over the years. This is one I cut several years ago -- that gold is pretty obvious since it's one of the very few metals that don't tarnish. Pyrite in quartz is often mistakenly thought to be gold. That is beautiful
Post by fernwood on Sept 6, 2018 5:36:14 GMT -5
Nice quartz. I like the hints of colors in some.
Post by MsAli on Sept 6, 2018 8:02:41 GMT -5
Nice quartz. I like the hints of colors in some. Some are really nice. There is one that has little red crystals in it.
Post by rockjunquie on Sept 6, 2018 12:03:11 GMT -5
I agree, it generally seems to be in unmistakable veins. There's a couple on ebay right now you can see. It's quite obvious.
Post by MsAli on Sept 6, 2018 12:18:25 GMT -5
Post by rockjunquie on Sept 6, 2018 12:20:20 GMT -5
gemfeller
Post by gemfeller on Sept 6, 2018 13:04:07 GMT -5
Post by MsAli on Sept 6, 2018 13:23:46 GMT -5
See that is what I get confused about. It coming in many forms and may be small. I would assume I would still be able to tell what it is Tat rose quartz is incredible. That would be a lucky find
gemfeller
Post by gemfeller on Sept 6, 2018 15:35:53 GMT -5
[quote author="MsAli " source="/post/1012439/thread" timestamp="1536258226 [/quote]See that is what I get confused about. It coming in many forms and may be small. I would assume I would still be able to tell what it is [/quote][/p] Simple test: gold is the most malleable of metals. It can be hammered into a sheet so thin it can transit light. If in doubt about a specimen test it with a pin or other sharp tool. If it's gold it will deform slightly. Pyrite will shatter into tiny pieces.
Post by MsAli on Sept 6, 2018 15:46:08 GMT -5
