dakotabirder
Member since July 2017
Post by dakotabirder on Sept 17, 2018 18:03:50 GMT -5
I could frankly fill up the "ID" page out here with things I find on the Buffalo Gap National Grasslands. This one stuck out like a sore thumb when I saw it lying there this weekend. Any idea what you'd call it? Certainly not the typical prairie/bubblegum/other agate I typically find there.
Post by Peruano on Sept 18, 2018 7:45:53 GMT -5
Its had a rough life and shows it on the surface. It sure appears that the grey-white is not the typical rind of an agate oxidation, but rather a distinct rock that enclosed or bordered the reddish jasper. It begs to be slabbed or windowed to see what kind of pattern might be hiding within that would justify a fancy agate name. Cutting off a small slice from one end would make it stand better even if you decided not to slab the entire specimen.
Post by fernwood on Sept 18, 2018 8:09:47 GMT -5
Could it be a mix of Granite or Quartz and Jasper? I have found some of those where I live. Mine are no where near as colorful.
Post by vegasjames on Sept 18, 2018 8:26:55 GMT -5
I don't know but if the colors go through that would make some awesome cabs.
Post by miket on Sept 18, 2018 9:21:12 GMT -5
That's pretty cool! I've never hunted the Buffalo Gap grasslands but I'm not far off in the Oglala grasslands and I think we probably find similar things. If you're ever in this area shoot me a message or just look for a bright yellow SUV crawling around the prairie!
Post by RickB on Sept 18, 2018 11:14:26 GMT -5
Nice. Looks like it should have some crime scene tape surrounding it.
Post by MsAli on Sept 18, 2018 14:45:46 GMT -5
That needs to be cut to see what is hiding inside
Post by Pat on Sept 18, 2018 15:38:52 GMT -5
Bleeding granite.
