braat
Member since December 2016
Post by braat on Oct 12, 2018 13:06:50 GMT -5
Best average overall shine yet as I'm getting better about what to tumble and what to weed out at my weekly cleanouts. Even the granite came out pretty good (if you can ignore the undercutting) but having said all that I was surprised at the pits, cracks etc I'm missing along the way so more attention needed there. This batch is mostly local finds with a couple reruns (1 agate and 1 petwood). Overall I'm pleased with this batch and can't wait for the next batch in 3 weeks!
Post by MsAli on Oct 12, 2018 13:15:52 GMT -5
NOt bad at all! I love the orangeish one on the left
Post by Drummond Island Rocks on Oct 12, 2018 13:16:45 GMT -5
Those look good to me. My favorite is up a little from bottom center. A large oval striped rock.
goatgrinder
Make mine a man cave
Member since January 2017
Post by goatgrinder on Oct 12, 2018 13:46:49 GMT -5
Very nice batch. I cannot wait to see the next. Cheers.
Post by Jugglerguy on Oct 12, 2018 16:35:35 GMT -5
Those look great to me. That brown striped one caught my eye too.
Post by aDave on Oct 12, 2018 17:33:35 GMT -5
Nice work. As far as missing pits and cracks in your inspections, are you checking the rocks while they are wet or dry? If you are doing them wet, the water on the rock can hide flaws that you might otherwise find when they are dry. I found that made a difference for me.
braat
Post by braat on Oct 12, 2018 18:50:20 GMT -5
Nice work. As far as missing pits and cracks in your inspections, are you checking the rocks while they are wet or dry? If you are doing them wet, the water on the rock can hide flaws that you might otherwise find when they are dry. I found that made a difference for me. That explains it....I'm checking when they're wet so that's likely why I've been missing things. Thanks for the tip! I'm learning so many little things can make or break a tumble...it's becoming clear to me once I find the "fine tune" that works I'd best stick to it
Post by jamesp on Oct 12, 2018 20:33:01 GMT -5
Looks like some granite received a polish. That's not easy to do.
Post by TheRock on Oct 13, 2018 0:52:08 GMT -5
Nice Tumble I like the brown striped one but the reddish spotted one just above to the left of brown one looks interesting.
Post by fernwood on Oct 13, 2018 4:28:41 GMT -5
The granite is looking good.
Post by Fossilman on Oct 13, 2018 8:14:01 GMT -5
Nice tumbles, great job..
Post by Garage Rocker on Oct 13, 2018 8:31:53 GMT -5
Nice batch, you put a super shine on 'em. Good advice from Dave about inspecting rocks dry at cleanout. I check them while they're wet and set any aside that could possibly move on. Once those are dry, they are checked again before going into the 'move along' tub.
Post by miket on Oct 13, 2018 9:35:14 GMT -5
Very nice!
braat
Post by braat on Oct 14, 2018 11:28:13 GMT -5
Thanks for all the encouraging comments and advice...it is appreciated!
Post by aDave on Oct 14, 2018 12:56:13 GMT -5
Nice batch, you put a super shine on 'em. Good advice from Dave about inspecting rocks dry at cleanout. I check them while they're wet and set any aside that could possibly move on. Once those are dry, they are checked again before going into the 'move along' tub. Thanks for clarifying Randy. I do the "set aside" thing as well. braat , as Randy made more clear, the inspection(s) to move along are actually a two step process (wet and dry).
braat
Post by braat on Oct 14, 2018 15:36:10 GMT -5
Nice batch, you put a super shine on 'em. Good advice from Dave about inspecting rocks dry at cleanout. I check them while they're wet and set any aside that could possibly move on. Once those are dry, they are checked again before going into the 'move along' tub. Thanks for clarifying Randy. I do the "set aside" thing as well. braat , as Randy made more clear, the inpection(s) to move along are actually a two step process (wet and dry). Check...cleanout process amended accordingly
mossyrockhound
Member since January 2011
Post by mossyrockhound on Oct 17, 2018 23:37:17 GMT -5
Nice batch. You've got a carnellian at about 2 o'clock that is a perfect pendant piece.
Good info on the "move along" tub.
