bmw2002
Member since April 2017
Post by bmw2002 on Nov 10, 2018 15:30:44 GMT -5
Has anyone used carbide tipped chisels to prospect? Are they worth the price when trying to break stone like green lizard rhyolite?
Thanks
NRG
Member since February 2018
Post by NRG on Nov 10, 2018 20:42:53 GMT -5
I use standard steel chisels sold at The Home Depot. Never had a stone complain yet.
Post by vegasjames on Nov 10, 2018 21:19:22 GMT -5
I picked up some railroad spikes by the train tracks. Working great for busting up the chalcedony. Thinking about taking them to the grinder to sharpen them up a little.
Post by quartz on Nov 10, 2018 21:27:31 GMT -5
I spent my working years largely as a machinist so carbide is a fairly common material to me. I would not recommend using a carbide tipped chisel on rock because of the brittleness of carbide. Good steel is hard to beat.
Post by aDave on Nov 10, 2018 23:31:22 GMT -5
I spent my working years largely as a machinist so carbide is a fairly common material to me. I would not recommend using a carbide tipped chisel on rock because of the brittleness of carbide. Good steel is hard to beat. I totally agree with this. While not speaking to chisels, I seem to remember in my former line of work that carbide tipped chainsaw blades were more brittle that common steel blades. I'd simply assume that would be the case with chisels, as well.
Post by parfive on Nov 11, 2018 1:23:49 GMT -5
Ain’t that brittle.
Ever use a Hilti hammer drill?
Post by quartz on Nov 11, 2018 23:06:33 GMT -5
Hilti's have a thick carbide cutting tip inserted into a slot in a steel shank, lots of support for a fairly thick piece of carbide vs. a near sharp chisel tip.
Post by grumpybill on Nov 14, 2018 8:37:17 GMT -5
As a brick/block/stone mason, I had carbide tips put on a few of my brick hammers. Never had one shatter and saved a lot of dressing/sharpening. Never tried a carbide tipped chisel, though.
