Post by TheRock on Nov 17, 2018 17:43:45 GMT -5
I may be a little "ANAL" but I try and keep my equipment looking good and well maintained. I am constantly cleaning the red paint off the black rubber rollers on the thumler. I know it doesn't bother the workings of the tumbler but I don't like it. I was thinking about getting a large Inner tube cutting a slice out of it and slipping it over the steel rim of the barrel and glue in place and let it spin rubber on rubber. Not only will it give the Barrel better traction but it will solve the friction of red paint being removed off the thumler B Barrel. Has anyone tried this? I took a picture of the Thumler B and used Microsoft Paint to render how it might look with this modification done. Let me know what you think. Thanks ~Duke
Post by johnjsgems on Nov 17, 2018 19:45:21 GMT -5
It should be OK. The really anal people are going to tell you adding the rubber will change barrel rotational velocity by the thickness of the rubber times pie are round.
Post by TheRock on Nov 18, 2018 1:47:24 GMT -5
It should be OK. The really anal people are going to tell you adding the rubber will change barrel rotational velocity by the thickness of the rubber times pie are round. I think I will PU an Inner tube and try it. If anything it will prevent another maintenance task of wiping down 16 rollers a couple times a week because I have 4 tumblers rolling
jimaz
Member since July 2018
Post by jimaz on Nov 18, 2018 11:46:50 GMT -5
If you could find the right size inner tube cutting a band might work. Might check at local tire stores to see if they have any throwaways.
Post by TheRock on Nov 25, 2018 7:29:32 GMT -5
I Got Em Done!
jimaz
Post by jimaz on Nov 25, 2018 14:08:12 GMT -5
Looks good!
agatemaggot
Member since August 2006
Post by agatemaggot on Nov 25, 2018 14:33:06 GMT -5
Nice clean fix !
