sophia13
RIP Jason Strickland, AKA sophia13
Member since March 2018
Post by sophia13 on Nov 22, 2018 11:35:24 GMT -5
Ok all:) Need a tutorial, pdf, something.... Tried to search for an Hp video, couldn't find. I took the front cover off the saw, exposed the gear. Took hex key screw off locking collar on inside of saw at front edge. Now, how do I remove the old feed screw to put a new one on and replace the bushings? Have removed feed dogs and other parts attached to carriage already. Thanks.
Post by Rockoonz on Nov 22, 2018 12:19:04 GMT -5
At the front of the shaft inside the saw tub is a shaft collar with a set screw that needs to be loosened so it can slide down the shaft as you pull it out of the front. My saw needs cleaning.
