Post by glennz01 on Jan 6, 2019 2:35:06 GMT -5
So recently the rubbery foam pad that graves made is pretty warn out and i should have replaced it a long time ago for final polish with a compound.. whats the best screw in product you guys found? I know im not going back to graves due to bad service.
Post by Rockoonz on Jan 6, 2019 3:04:22 GMT -5
Does your shaft have 1/4" female threads in the end like a Genie? If so the Nova ends are good, also I believe Crystallite still makes similar ones too. I don't think Graves as a company even exists anymore.
Post by glennz01 on Jan 6, 2019 20:24:02 GMT -5
Does your shaft have 1/4" female threads in the end like a Genie? If so the Nova ends are good, also I believe Crystallite still makes similar ones too. I don't think Graves as a company even exists anymore. yep same thing
stonemon
Member since January 2017
Post by stonemon on Jan 6, 2019 20:28:50 GMT -5
I use a couple of different pads. My agate/jasper hard stone is a simple canvas with 50,000 diamond paste. I also have some set up with alox and cerium which I can add water to. It is so easy to change, I mostly try to use the one that works best for the material I am working.. Bill
