This a Brazilian Agate that came with the wife's estate sale rock pile, someone had cut it and got what is shown in the first photo. looks like they hit a water line, I recut and second photo is what I got. I do need to repolish this one.
"Conversation should be more like ping-pong, and less like archery.” — Alan Alda "The good thing about science is that it’s true whether or not you believe in it.” — Neil DeGrasse Tyson
Thank you for your video!!! That really helped me see how "luck" aka experience and knowledge, worked for you. I bet you just knew, maybe without realizing it, that the stone was hiding something beautiful. I haven't even cut 1 stone - the workshed is still under construction- and I have all sorts of questions about how to read stones and know where to cut. I read this forum and other groups and am trying to learn by osmosis. Your video was perfect!
Yup, luck of the cut alright! Sometimes cutting with the water lines can produce some amazing results, but in this case your rotation was the winning formula!
Reading the finished image using information from the first.
First:
Last:
This started as a gas (probably H2O) bubble rising through molten basalt, stopping as the basalt cooled. steam condensed, dripped down the sides and formed a small pool on the floor and a vacuum in the chamber.
MANY years later moisture began entering through tiny fractures in the surrounding basalt. note the debris that fell from the sides and littered the bottom of the void.
High ph (basic) dissolves silica. Low ph (acidic) causes silica to precipitate - in the first stage as waterline agate/opal.
Later volcanic action reheated the area driving hot silica water into the chamber forming (fortification agate) alternating layers of moganite and chalcedony to stick to all surfaces.
The remaining space reached the temperature point where quartz crystals could form, Then spheroids (probably crystobalite) formed in the remaining open space.
Note the melted points of the last quartz crystals.
Rule of thumb. If you get an agate with a flat side its possibly a waterline (parallel banding) so just rotate and cut at 90 degrees to the flat spot, no harm done if its just a flat spot but if its a waterline you get the best banding. I occasionally take a slice off parallel with the water line if its strongly banded and cut a round cab with a nice bullseye.
Warzy Raptor: Nah that’s the DMV for sure!
May 3, 2024 1:05:56 GMT -5
Wooferhound: My phone is constantly still ringing constantly
May 4, 2024 10:26:44 GMT -5
ThomasT: Turn it off... drop out and tune in. Life is short...
May 5, 2024 19:16:43 GMT -5
Wooferhound: Ding-a-Ling
May 5, 2024 21:06:09 GMT -5
amygdule: Don't call me, I have Phone-Phobia...
May 6, 2024 1:38:10 GMT -5
Wooferhound: Are you interested in Changing your Long Distance service ?
May 6, 2024 7:50:13 GMT -5
RickB: "Is this the party to whom I am speaking?"
May 6, 2024 8:15:06 GMT -5
Wooferhound: Have you got Prince Albert in a can ?
May 6, 2024 14:56:44 GMT -5
parfive: Nah, they parked Eddie in a big oak box.
May 6, 2024 16:04:57 GMT -5
Wooferhound: Doing an Appliance Survey . . . is your Refrigerator Running ?
May 6, 2024 17:03:22 GMT -5
RickB: I thought the dryer was shrinking my clothes... Turns out it was the refrigerator all along.
May 6, 2024 19:31:44 GMT -5
werejen: I need opinions on rocks that cannot safely be tumbled. I have found a lot of quartz/mix with nice edges that I do not want to lose. Some have told me to use lacquer on them, and others have said a clear coat nail polish. Thoughts?
May 6, 2024 21:22:55 GMT -5
1dave: werejen, you are in the wrong place.
May 7, 2024 9:59:24 GMT -5
ThomasT: The rare Double brood of Cicadas coming out now... last time this occurred Thomas Jefferson was President...
May 7, 2024 17:42:04 GMT -5
ThomasT: Cicadas 13- and 17-year emergence cycles align only once every 221 years... much rarer than a solar Eclipse. Next event will be in the year 2245 AD. Woohoo
May 7, 2024 17:55:50 GMT -5
