I'm looking at putting together a polisher similar to those in the DIY section. I have exactly zero experience with laps. I've seen some posts mentioning RPMs and grit stages, but not sure what to aim forI've got a motor laying around that's 1/5hp and 825 rpm. How would that work for direct drive?
A lap and a polisher are two different animals! if you want to use grit that RPM is way too fast. This is a polisher, it only uses cerium oxide on it. the lap is a similar machine and I only use 120 grit on it. In Between the two I use a bull wheel sander using 100 gt, 220 gt, and 400grit.
Thanks for the clarification. What I'm looking at are the designs that use the diamond pads for slab polishing
I had an ameritec 8 inch one that used diamond pads, worked fairly well but I was not using it so I sold it to a member on here, It had a variable speed control. you might look at them and get an idea of what you ant to build.
RWA3006: I heard sriracha is getting scarce again.
May 13, 2024 21:59:57 GMT -5
parfive: Les cucaracha are always in season.
May 14, 2024 0:14:28 GMT -5
wargrafix: *in a sad country tune* "Won't someone have some sympathy for this poor lonely rockless soul"
May 14, 2024 13:53:14 GMT -5
wargrafix: *someone at the back* "Lies! I heard he bought geodes this month!"
May 14, 2024 13:53:46 GMT -5
amygdule: The Ocean is still tumbling on May 15, 2024
May 15, 2024 21:57:49 GMT -5
Wooferhound: Tumbling like a tumbleweed , pledging it's love for the ground.
May 16, 2024 6:21:49 GMT -5
RickB: Drifting along with the tumblin' tumbleweeds
May 16, 2024 8:59:23 GMT -5
Wooferhound: Imperfect memory and false recollections are essential elements of a flexible mind.
May 17, 2024 16:40:58 GMT -5
Wooferhound: My mind is flexible like Rock Slurry
May 17, 2024 21:06:47 GMT -5
Wooferhound: I grease the wheels in a factory, hunched over metal machines , the gears moving remind me of bodies in motion
May 17, 2024 22:40:28 GMT -5
