gatorflash1
Post by gatorflash1 on Feb 2, 2019 13:04:31 GMT -5
I have seen so many different beautiful colors and patterns of granite counter tops I'm wondering why the tumbling community hasn't jumped on this rock. I know if there is a lot of mica in the granite it will undercut yet the granite countertop folks have seemed to figure out how to put a fantastic finish on it. I've always been an agate aficionado but am thinking I should break out. I'm not a big fan of solid bland colored tumbles no matter how shiny they are. I've seen too much blah quartz, etc. Thoughts? www.forbes.com/sites/trevornace/2016/06/05/granite-colors-white-black-countertops/#67bb0d237b98
Post by Rockoonz on Feb 2, 2019 14:55:24 GMT -5
Granite often contains calcite, which gasses off when tumbling. Us relatively lazy tumblers who don't want to fool with the barrels more than once a week avoid anything that might contain calcite. Marble is really bad.
braat
Member since December 2016
Post by braat on Feb 2, 2019 15:58:18 GMT -5
In my 2 1/2 years of tumbling I've done lots of granite because other than quartz and some fairly bland jasper that's all that there is to rockhound around here. Granite is appealing in the wild but it undercuts like crazy which to my shiny oriented eyes and brain is very distracting and it seems I'm not alone. I have two large trays on my coffee table full of my best tumbled rocks....one tray is shiny quartz and shiny brown, red and butterscotch jasper...the other tray tray is mostly granite with some shiny black basalt and a few shiny agates(not from around here). When people see the 2 trays they nearly always go for the first tray. It's an individual thing for sure but for me shiny beats undercutting any day no matter how shiny the rest of the granite is. I don't rockhound it any more unless there's some striking color or patterns going on. Having said all that I still have some granite in the tumbling queue so If you see some granite in near future photos it's not because I'm picking it up anymore...
Post by Jugglerguy on Feb 2, 2019 18:27:43 GMT -5
Granite often contains calcite, which gasses off when tumbling. Us relatively lazy tumblers who don't want to fool with the barrels more than once a week avoid anything that might contain calcite. Marble is really bad. I’m pretty sure that granite does not contain calcite. I’ve tumbled a fair amount and have never had a gassing off problem with it. The reason I don’t tumble it anymore is the undercutting. I do tumble quite a few Petoskey Stones, which are made of calcite, and those don’t make my barrels bulge either. Granite actually takes a pretty good shine, but the black parts don’t shine and wear away faster so your left with little, dull trenches in the finished rocks.
Post by fernwood on Feb 2, 2019 19:45:23 GMT -5
I tumble both granite and petoskey. No blow outs (yet). I do not burp/check the tumblers daily. The granite is self collected from my land. Some achieved a great, even shine. It all depends on the composition of the granite.
I have lots of granite counter scraps which I want to cut into tumble sizes. That will need to wait until summer.
Post by vegasjames on Feb 2, 2019 20:34:50 GMT -5
One thing is that as your article also points out a lot of "granite" is not really granite.
I think another issue is that a lot of people don't bother to look for granite as they often think it is just black and white. I have found some nice green and green and pink mixed granite South of here. Did not have much of a use for it though so I did not pick up much of it.
gatorflash1
Post by gatorflash1 on Feb 3, 2019 9:08:16 GMT -5
Thanks for all the good info. Granite seems very common and colorful with great patterns. I'm wondering how to stop the undercutting, if possible.
Does granite round out quickly and if so would limiting stage 1 reduce the undercutting? I'm thinking it is in the Mohs 6-7 range.
I really like all the colors and patterns of granite, or what passes for it, at the local countertop store. They have a huge dumpster full of various granite scraps in the back of the store and said "Feel Free" when I asked them about taking a few pieces. Maybe I'll do some experimentation and see what I come up with. I just bought a Thumler's UV-18 is on the way. Between my TT model B and that I'll see what I can do with some nice granite.
I know you can put a spoon of baking soda into the mix it is supposed to stop the gas build up.
I have cabbed granite on my DP Titan and never had issues with it, but that is a much more controlled process.
Post by Jugglerguy on Feb 3, 2019 10:44:03 GMT -5
The undercutting takes place in the later steps, not the first. Shortening the later stages should help.
Post by jamesp on Feb 4, 2019 12:22:07 GMT -5
Just having sections of quartz and felspar creates issues with granite. Granite by definition is composed of 80% felspar and quartz. The felspar is going to cut faster being softer than quartz and the tumbling process will leave an uneven surface often referred to as undercutting. (Granite) gneiss is another animal, it usually tumbles better having gone thru a metamorphic process often resembles granite. Granitic gneiss is seriously overlooked for a tumbling choice. But it can be difficult to differentiate from granite. Wavy patterns and banding caused by metamorphosis are one telling hint that you have gneiss. It is often found near granite sources. "Gneisses that are metamorphosed igneous rocks or their equivalent are termed granite gneisses, dolomitic gneiss, etc."
lookatthat
Member since May 2017
Post by lookatthat on Feb 4, 2019 12:49:31 GMT -5
Tumbler's lament: "I thought it was gneiss, but it was just a piece od schist."
Kai
Member since December 2018
Post by Kai on Feb 4, 2019 15:44:19 GMT -5
goatgrinder
Make mine a man cave
Member since January 2017
Post by goatgrinder on Feb 4, 2019 16:24:16 GMT -5
I have tumbled a good bit of granite 'cuz I live in Atlanta, but the prettiest that I have worked is the pyrophorblastic granite that I get out of the Vulcan mine just north of Kennesaw. Large crystals of feldspar and lots of blue silica. The blue really pops in full sun after a rain and is largely retained by a good high polish tumble. Vulcan tells us this rock is 1.2 billion years old; why wait?
For the other granite its just easier to cab after the initial shaping and maybe up to #200 grit shine in the tumbler.
Post by Rockoonz on Feb 4, 2019 20:34:44 GMT -5
Tumbler's lament: "I thought it was gneiss, but it was just a piece od schist." Don't take it for granite...
gatorflash1
Post by gatorflash1 on Feb 5, 2019 8:23:21 GMT -5
JamsSP - you said granite is 80% feldspar and quartz. Here is the definition I found on Wiki-pedia which defines it as having as really having a wide very wide combination of quartz and feldspar. As some have already stated the word Granite covers a large range of different rocks. I thought it interesting that there are "A" type, "H" type, and "M" types of granite. Hardness is in the 6-7 range, slightly less than quartz so it should make some good tumbled stones. The stuff is so common, and the cost so cheap, and the colors and patterns so varied, I just have to give it a shot. en.wikipedia.org/wiki/Granite
hnhstngs
Member since September 2018
Post by hnhstngs on Feb 5, 2019 9:04:23 GMT -5
I don't think the problem with consistently producing good, tumbled granite is due to the 80% quartz/feldspar. It's the remaining 20% of the rock's make-up that causes me headaches. Mica and hornblende are both softer than the feldspar and quartz producing undercutting in the stones.
I can get lots of nicely water-shaped granite stones right off the dirt roads in the Adirondacks. Some polish up nicely. Others undercut like crazy. I haven't done a lot of it yet but I did notice that trying to tumble all the way through in a rotary produced more undercutting than running them in a vibratory tumbler. I've got a bunch of stones that I'm going to start over with in a small barrel (3-4 lb) to see if I can even out the surface before switching them to a UV-3.
Post by Jugglerguy on Feb 5, 2019 16:39:05 GMT -5
I don't think the problem with consistently producing good, tumbled granite is due to the 80% quartz/feldspar. It's the remaining 20% of the rock's make-up that causes me headaches. Mica and hornblende are both softer than the feldspar and quartz producing undercutting in the stones. I can get lots of nicely water-shaped granite stones right off the dirt roads in the Adirondacks. Some polish up nicely. Others undercut like crazy. I haven't done a lot of it yet but I did notice that trying to tumble all the way through in a rotary produced more undercutting than running them in a vibratory tumbler. I've got a bunch of stones that I'm going to start over with in a small barrel (3-4 lb) to see if I can even out the surface before switching them to a UV-3. That’s what I see too. It’s the dark colors that undercut, not the colorful or lighter colors.
Post by jamesp on Feb 8, 2019 7:10:26 GMT -5
I wish you luck gatorflash1. This is a tray of pink granite like stones. Collected from gravel along a railroad track. Probably a mix of gneiss, granite and similar to granite stones. Just saying that I.D. can be tricky. The pink color is about certainly pink felspar. I failed at polishing these. And had undercutting. The biotite did not help matters. If you are out collecting in a granite rich location you will likely find some pure pink or white felspar. You might consider tossing some pure felspar in with your granite load and see how it tumbles since granite is composed of felspar. Felspar can be a tricky tumble. Felspar is Mohs 6 and quartz is Mohs 7. Knoop hardness is another useful hardness number the quantifies hardness. Felspar is quite a bit softer than quartz when looked in terms of Knoop numbers, actually closer to glass(530) at 560 verses quartz at 820. Knoop 560 is normally a tricky-to-polish tumble. Note aluminum oxide(alumina) is Knoops 2100 and silicon carbide is Knoop 2480 and silicon carbide is far more aggressive than alum ox. Garnet at 1360 will polish quartz but it takes a long time.
Post by jamesp on Feb 8, 2019 7:38:19 GMT -5
Amazonite and labradorite are other felspars that can be tricky to tumble. For me anyway. Other members may have had success with these two rocks.
gatorflash1
Post by gatorflash1 on Feb 8, 2019 8:35:16 GMT -5
Thanks to all for the good info. I have cabbed granite with excellent grinding and polishing results, but using a cab machine is a much more controlled and faster process than tumbling. Granite and related comes in just about every color of the rainbow, great patterns, and is very low in cost, mostly free, which appeals to my Scotch ancestry. The counter shops in my area, which is not agate rich, seem to have tons of scrap behind the shops or in the dumpsters which is free for the taking as it is otherwise headed for the local dump. The granites I polished were very fine grained which is probably the secret to getting good tumbled granite. James it looks like you have a good supply of rough to work with. I wish I lived closer as I would try to polish it with the diamond lap on my cab machine.
avenueiarts
Member since February 2019
Post by avenueiarts on Feb 10, 2019 17:42:51 GMT -5
I have seen so many different beautiful colors and patterns of granite counter tops I'm wondering why the tumbling community hasn't jumped on this rock. I know if there is a lot of mica in the granite it will undercut yet the granite countertop folks have seemed to figure out how to put a fantastic finish on it. I've always been an agate aficionado but am thinking I should break out. I'm not a big fan of solid bland colored tumbles no matter how shiny they are. I've seen too much blah quartz, etc. Thoughts? www.forbes.com/sites/trevornace/2016/06/05/granite-colors-white-black-countertops/#67bb0d237b98The last picture on the right hasn't been tumbled yet, correct? It sure makes a big difference!
