mikeinsjc
Member since June 2010
Post by mikeinsjc on Feb 19, 2019 12:10:08 GMT -5
Is anyone using walnut shells in their tumbling? Is yes, would you mind describing your recipe? Are they used dry?
gatorflash1
Post by gatorflash1 on Feb 25, 2019 19:01:11 GMT -5
I reload cartridges and use walnut shells dry in my rotary tumbler to clean and polish the cartridge cases. I would not use them for rocks because they are to soft, even if used dry.
pizzano
Member since February 2018
Post by pizzano on Feb 25, 2019 20:52:16 GMT -5
I use the Harbor Freight course walnut shells for cleaning and burnishing in the vibes.........if the stones don't have that eye popping ice cube look after final polish. I let the stones tumble dry (after everything has been washed, scrubbed and dried), for up to three hours. That is if necessary.........nothing can replace the proper previous cycle stage prep and polish. But the walnut has helped with the final cleaning of Cerium Oxide in particular.........mostly on Agates and Jasper, not so much on quartz or crystalized based material.......just my experience.
Note.......it works fantastic on copper, nickel plated shell casings........if one reloads.
