rockytop
Member since January 2017
Post by rockytop on Apr 28, 2019 21:11:48 GMT -5
flminer56
Im a certified us faceters guild novice gem cutter as of 4/20
Member since September 2017
Post by flminer56 on Apr 29, 2019 16:43:04 GMT -5
I know that a member of the us faceters guild bought one but he never gave any feedback about it. These don't seem to have a radial index adjustment also known as a cheater. One of these might cause you more grief than its worth.
rockytop
Post by rockytop on Apr 29, 2019 19:47:56 GMT -5
Thank you for your input.
slomoshun
Experienced bad influence
Member since April 2018
Post by slomoshun on Apr 29, 2019 21:04:24 GMT -5
It can repeat facets more accurately than a jam-peg setup, but don't expect meet points.
Consider what is missing. If you factor in everything else needed to cut stones with it, you would be money and time ahead buying a used faceting machine from eBait or Craigs.
Post by pauls on Apr 29, 2019 21:10:50 GMT -5
That is only a small part of the faceting operation. You need dops, laps, transfer jig, and an actual lap machine to mount that on. To my thinking that mast is far too flimsy for good work.
Far better for your first machine to buy a good second hand machine, they aren't cheap but hold their value so if you decide it's not for you you can sell it for pretty much what you paid. Join a club and have a go of their machines, put out feelers for a machine, people get old and their eyesight deteriorates so need to sell up. A good second hand machine from someone you know in your club will often come with hundreds of dollars worth of accesories.
QuailRiver
Post by QuailRiver on Apr 29, 2019 22:19:23 GMT -5
The mast design appears to be based on the old LEE machine mast. Several years back Daniel Lopacki attempted to have a line of machines based on the LEE design manufactured overseas and from what I remember they never could get the accuracy machined quite right. That said a skilled faceter can adapt and cut a good stone on most any machine. However, it can take that same faceter MUCH longer to cut a quality stone on a machine with poor repeatability than on a good machine. And also it could be frustrating for a beginner trying to learn to facet on a machine with poor accuracy. Another consideration is that most of the Asian made machines use 6mm diameter shaft dops, so finding dops to fit this machine here in the U.S. might be a challenge.
Larry C.
rockytop
Post by rockytop on Apr 30, 2019 19:22:19 GMT -5
Thanks to everyone for the input. I appreciate the insights. I believe finding a good used machine would be a better idea.
Post by pauls on May 1, 2019 0:01:47 GMT -5
If you are new to faceting check out "Amateur gemstone Faceting" by Tom Herbst. There are two books but volume 1 is all you will need to get started, vol 2 covers some pretty advanced topics. They are quite cheap and for technical books very easy to read, the author has a way of explaining quite complicated stuff that will have you absorbing it easily. I got mine on Amazon, it was here in 4 or 5 days in Australia.
